Need help with error code
Old Aug 27, 2013 | 04:54 AM
aloy886's Avatar
Hi all, i need help with this error p1887. Seem like something to do with P1887 - TCC Release Switch Circuit .
Thanks.
Old Aug 28, 2013 | 02:16 AM
bigiepigie's Avatar
ok so your answer is in your question, its either the tcc solenoid or its a circuit issue, if you have access to a noid light hook it up to your tcc connector and go for a drive, if you light up when your tcc is supposed to activate then you know your getting signal and can assume its the solenoid itself.
vinnimac
Aug 31, 2017 11:29 PM
Chad_92
Jan 30, 2013 01:24 AM
AtticusFit
Dec 7, 2011 08:11 PM
madvibes
Aug 31, 2010 07:16 PM
jim beam
May 4, 2005 11:16 AM
