Voltage Issue, or Noise, or Not?
Old Nov 6, 2013 | 08:37 PM
EXCellR8's Avatar
Got another quirky little issue to deal with, at some point anyway. When I'm running the heater and it switches on the whole car kinda skips a beat like; the lights dim a little for a second. Sounds minor I know but it's actually pretty annoying. The motor is also slightly affected as it gives a little lurch. Swapped the battery which helped a tiny bit but it's still noticeable... especially at lower rpm. New unit is a AutoCraft 151R.
Kinda gotta figure it's an electrical anomaly but I haven't a clue where to start. Heater works fine and will get plenty warm but it really bugs the crap out of me. I know it's a little car but I feel something is gotta be off. Less noticeable when the engine is more wound up but still there.
Any ideas? Like I said, brand new battery, and I haven't made any changes to the electrical, ignition, audio, etc. etc. everything is stock. No CEL or any obvious indications that something is broken. Was thinking maybe a bad ground but I haven't touched anything...
Old Nov 6, 2013 | 08:51 PM
Wanderer.'s Avatar
Are you using the defroster as well as the heater? If you're using the defroster that's the A/C compressor kicking on. Shouldn't do much just running the heater by itself.
Old Nov 6, 2013 | 09:23 PM
EXCellR8's Avatar
Yea I typically use the front defroster so maybe i'll just stick to using the heater once i'm warmed up. If I remember correctly it does the same thing when I run the A/C so makes sense if it's just the compressor. Still kinda bothers me but it's a sub compact so I guess it's to be expected.
Old Nov 7, 2013 | 02:14 AM
loudbang's Avatar
Nothing wrong with the car. Check this thread
for post #43 for more info
https://www.fitfreak.net/forums/gene...ckering-3.html
ColoradoFIT13
Aug 30, 2015 03:16 PM
budro
Jul 25, 2015 11:38 AM
Mister Coffee
Mar 28, 2015 12:22 PM
Mini_Odyssey
Apr 21, 2013 07:37 PM
DoctorExplosivo
Aug 25, 2010 02:32 PM
