Need Cheap Battery Tie Down
Old Dec 9, 2013 | 01:37 PM
Anthony Berke's Avatar
Hello All,
I just found that somehow the battery tie down of my 07 Fit is missing from one side and I need a replacement. I looked on ebay and found the whole tie down system for $20 including shipping, but I do not want to spend that much if anyone here knows of a cheaper place that sells parts. Does anyone know of such a place? Or do I even need the tie down since it is pretty cramped in there?
Also, is it usual for the terminals to slide on and off with ease or should I see if they tighten?
Thank you for the assistance!
Anthony
Old Dec 9, 2013 | 06:57 PM
DrewE's Avatar
Originally Posted by Anthony Berke
Hello All,
Anthony
Bernardi (bernardiparts.com) has the hold down rods listed for $3.50. It appears that the two sides are slightly different lengths, so you'd want to make sure you get the proper one. A local dealer could probably supply the rod for less than $20, too.
Alternately, it looks to me as though it would be straightforward to make a workable one out of a length of threaded rod of an appropriate diameter. Just trim to length, bend one end to suit, and stick a nut and washer on the other end.
The battery hold-down is a safety device; it helps prevent the battery from shifting around and shorting out in an accident or bad bump. It's obviously not an essential part of the car, in that the car will drive just fine without it, but it's definitely something I want to have in place on my own car.
The connectors should not slide off the battery posts. They have bolts running horizontally through the terminals to tighten them around the battery posts; cinching down on these bolts some will generally solve that problem; if not, it may be necessary to put a shim in between the battery post and the connector. Shims are available from auto parts stores, etc.; or a bit of sheet copper cut to size would work. A loose battery connection can cause strange behaviors and/or trouble starting the car.
Old Dec 9, 2013 | 08:18 PM
Thanks a bunch!
Old Dec 9, 2013 | 08:33 PM
13fit's Avatar
parts stores have generic ones that should fit fine for cheap as well
Old Dec 9, 2013 | 10:25 PM
Wanderer.'s Avatar
Bungee cords are a couple bucks or maybe free in your garage.
JK?
Old Dec 10, 2013 | 09:29 AM
Carbuff2's Avatar
JK?
Hope so, because you don't want a false sense of security with a battery retainer that stretches.
Batteries are very massive.
jchcmax
Jan 5, 2014 02:54 PM
jimsmith101
Oct 18, 2012 09:08 PM
phenoyz
Aug 10, 2012 09:04 AM
leisuredress
Jul 10, 2010 01:49 PM
Karvin Karl
Sep 28, 2008 10:51 PM
