Rear wiper washer and third brake light not working
So,
it just came to my attention that my third brake light doesn't work and my rear washer doesn't work. Is this a fuse problem?
I know the rear wiper works.
I just looked at my manual. It is not a fuse.and they are separate items.
Do you have brake lights? If so then you have a burned out 3rd light or a broken wire likely where it crosses from body to hatch. Same with the washer. I would suspect you have a broken or pinched hose where it crosses from body to hatch.
Anyhow that is my guesses. Let us know what you find.
I think it's also worth noting that the Fit was rear ended and the tailgate was replaced.
The brake lights work, everything works including the rear wiper and license plate lights. Except the third and the washer.
I could care less about the washer. I'll get a bulb soon and see if it works.
Thanks for your help.
