CEL, PO304 Code for 2008 Fit?
Old Feb 20, 2014 | 09:47 PM
Letsclique's Avatar
A couple weeks when I started car in the morning, the Check Engine Light came on. It was on all that day of driving, then the next morning. Then that second evening when I was leaving work, it wasn't lit after I started the car. I have noticed a drop in fuel economy, A couple tanks back I was getting around 200 miles a tank.
Then yesterday morning, this morning, and at lunch time it stayed lit after I started car. I thought I smelled gas, when leaving work today, though I have my vents open to bring in outside air (don't know if I am just smelling the exhaust). A couple hours ago I noticed it was not on after I started the car.
I drove to an O'Reilly Auto Parts store to use their OBDII scanner for free. The code that came up was: PO304, Cylinder 4 Misfire Detected.
The woman at the parts store said it could just be a spark plug wire that is loose.
I read on here that people have replaced their coil packs, spark plugs, etc.
Have you had the PO304 code, and what was your fix?
Thanks
2008 Honda Fit Sport
Automatic Transmission
~82,000 miles
Owned since February 22nd, 2013
when it had ~62,000 Miles
Old Feb 20, 2014 | 11:08 PM
ikutoisahobo's Avatar
I have the same problem, but I know how to fix it. I just don't want to.
It's the coil packs, I had the problem at around 90k-ish miles, and I replaced all the packs with cheap aftermarket ones and they only lasted about 20k miles. I recommend going with OEMs, or just something not super cheap like I did.
Just a tip: Don't replace only one coil pack, do them all, because if one failed, there's a good chance the others are also on their last leg.
Old Feb 21, 2014 | 12:32 AM
Do0ki3_pwn5's Avatar
coil pack gone bad, had the same thing about 2 weeks ago
went the cheap route, seems to be working fine.... but if i had the money i would have gone oem :/
Old Feb 21, 2014 | 02:48 AM
MTLian's Avatar
Rather than go OEM you can buy the Hitachi coils that are identical to the new OEM coils (made for Honda by hitachi). Rockauto.com has them for about 40$ a piece I believe. It's not exactly cheap for a set of four buts it's cheaper than honda which is about 70$ a coil.
Old Feb 25, 2014 | 11:36 AM
swade's Avatar
$70 from honda? Even with my discount they are over $80... I'll def look into hitachi as all mine have needed changed for awhile now...
Old Feb 25, 2014 | 02:38 PM
You can get the OEM Hitachi's from Rockauto for 50 bucks a coil.
The Hitachi is OEM.
Old Feb 25, 2014 | 05:04 PM
MTLian's Avatar
I just said that price off the top of my head. You are right, they might be even more than twice the price than the Hitachis on rockauto. Absolutely ridiculous to pay that much for a Hitachi coil that is simply rebranded as Honda.
Old Apr 13, 2014 | 11:29 PM
Letsclique's Avatar
Thanks for your help!
Old Apr 13, 2014 | 11:31 PM
Letsclique's Avatar
The Hitachi is OEM.
Thanks for the help!
Old Apr 13, 2014 | 11:36 PM
Letsclique's Avatar
Yes, I went the cheap route too. But will save up for some OEM coil packs. I bought a set of 4 coil packs for $50 total, on ebay, just cause I am trying to save with all the debts I have. The ebay seller had a "Buy it Now" price of about $64, but they also did the "Best Offer" thing. So, I offered $50, and the seller accepted.
Old Apr 19, 2016 | 09:14 PM
Latebrake54's Avatar
confusing troubleshooting
Thanks
~82,000 miles
When I got a misfire and a P0304 code, I switched the coil packs from cylinders 3 and 4, expecting the code to either follow the coil pack to cylinder 3 (bad coil pack) or remain on 4 (some other problem with 4 like injector or tight valve). To my surprise, the misfire went away and the code has yet to return.
Any ideas?
Old Jan 24, 2022 | 08:18 PM
markmcfail's Avatar
Thanks
~82,000 miles
I own a 2007 Honda Fit Sport with the same issue. I changed the coil packs and it solved the problem, I bought the car new in 2007 and have about 208,000 miles on it. I have changed the coil packs 3 times since I've had it. I have heard that this an issue with these first generation Fits. That check engine has been on and off lately and it looks like I'll have to change them again soon.
Old Jan 25, 2022 | 05:30 AM
mobby_6kl's Avatar
Oof, I hope this doesn't come up any time soon since I have 8 coils on this baby and it'll cost more to replace all of them than the car is worth
That said, so far so good, about 110k miles and running smoothly.
angus.mundy
Dec 15, 2024 12:16 AM
Globalksp
Jun 20, 2021 11:36 PM
Nussjohnathan@gmail.com
Nov 23, 2020 09:03 PM
buzlink
Oct 15, 2018 04:47 PM
MikeSwope
Oct 25, 2013 12:15 AM
