will not start
Old Apr 15, 2014 | 11:26 AM
JimD's Avatar
will not start
MY 2007 Quit and will not start it acts like it is out of time Almost starts and then backfires a little thru the intake when you stop, it pulls P2646.p0365and p119 , I replaced the VTEC value the cam pos sensor and the crankshaft pos senor and still the same any ideas.Thank you JimD
Old Apr 15, 2014 | 02:36 PM
D429302's Avatar
For P2646 there is a service bulletin to replace the vtec rocker arm oil pressure switch. After replacing the CMP sensor does p0365 still come on? if so than there may be a break somewhere in the harness. your gonna have to diagnose where the break is. As for p119 that's not a proper obd code. are you missing a number? how many miles and how often do you change your oil? if your car is out of time than your timing chain may be stretched.
Old Apr 17, 2014 | 09:56 AM
JimD's Avatar
Due to a trun of bad weather and needing my car I had it towed into a Honda dealer and will update what they figure out. I think you are right that there is a open in the harness. Thanks for the help JimD
Old Apr 24, 2014 | 11:00 AM
JimD's Avatar
Just to update on the fit 2007 that will not start,the honda dealer fixed it for 900 bucks. I had said it acted like it was out of time and that ended up being that only one cylinder was firing. so they replaced all the coils and changed the oil new plugs and it running great.I had replaced the VTEC valve and cam pos sensor and the crankshaft sensor.before it went in so I donot know if these really need changing but so be it. JimD
gilbie99
Jun 19, 2023 12:39 PM
crazy_shadow
May 16, 2017 04:57 AM
kd4pbj
Nov 8, 2016 08:04 PM
npreuninger
Mar 13, 2013 11:41 AM
Fitlooker
Apr 3, 2010 09:32 PM
