k swap
Old Nov 10, 2014 | 03:18 AM
gdnatty's Avatar
k swap
What's up FF I'm new tone the fit world but will be k swapping my GD3. I've done some research on the swap an am confident I can do the work. I was wondering if you guys could help me out and point me in the right direction for the wiring? Also any advice on the swap is greatly appreciated. Thanks in advance.
Old Nov 10, 2014 | 07:28 AM
DWils's Avatar
I researched the k swap using threads here a while ago. I pretty much learned two things: 1 it is butt expensive, and 2 there is no way I could do it myself. So I bought a K24Z7 instead. Thankfully it came with a 2012 Civic Si around it so I wouldn't have to worry about making sure everything fit. Good luck!
Old Nov 10, 2014 | 08:35 AM
Rollerboots666's Avatar
Yeah from I gathered through the years the K swap can run yeah some bucks. But if your trying to build then L15 in a serious manner the K swap is fair in pricing with much more power and potential.
Old Nov 10, 2014 | 01:23 PM
dewthedew's Avatar
ha, thats awesome
how is that motor? i just noticed the other day theyre putting k24s in the newer SI's
thinking about putting a k24 in my GFs civic si EP3
Old Nov 10, 2014 | 04:11 PM
gdnatty's Avatar
Lol that's hilarious. I drove the new si a while back the torque was very nice. I'm planning one doing the 20a3 or the 24a4 this vtec cams as vtec killers on 10-15 psi. I will also be doing an auto to manual swap in the process, which shouldn't be hard given the fact everything has to be changed anyhow. I don't care if it takes 2 years to gather all the parts, I'm gonna do it just because of the challenge I will definitely post a full write up here.
Old Nov 10, 2014 | 05:26 PM
viperpit07's Avatar
I hope you get her all done and set up good, arent enough k swap fits out there and we need a few more!
Old Nov 10, 2014 | 10:05 PM
MNfit's Avatar
check out these two threads they should have some good info about K swap
https://www.fitfreak.net/forums/fit-...iscussion.html
https://www.fitfreak.net/forums/fit-...ead-no-bs.html
Old Dec 1, 2014 | 02:57 AM
gdnatty's Avatar
Thanks man, I appreciate it. I will check them out. I'm still wanting to do this swap so I hope I can get everything worked out and get it done
Old Sep 2, 2015 | 06:24 PM
Nicx1st's Avatar
Need some advice
Hey everybody, I was wondering if i can get some advice from you about the Honda Fit K20 Swap… I’m in the process of doing the swap and want to know these answers:
1) Is the swap hard to do?
2) Is it the DC5 Type R K20a Engine with Transmission and with engine harness and Suspension, Brakes, Axles???
3) Which Radiator do i use? The one with the original Honda Fit or the one from the DC5 Type R??
I need some advice on how the swap is going to go.
Edison Carasio
Feb 21, 2009 06:29 PM
porkchop
Feb 19, 2009 04:14 PM
Bukwheat
Sep 25, 2008 07:02 PM
ascGD3
Nov 12, 2007 02:56 PM
j5ive
May 21, 2007 07:12 PM
