Rough Idle and Acceleration
Old Jan 1, 2016 | 12:12 PM
Sean McKenzie-Mardelli's Avatar
Solved! It was a bad coil pack on cylinder 3!
Old Jan 1, 2016 | 12:19 PM
Now I just hope that 2000 miles on a dead coil pack didn't mess up my catalytic converter
Old Jan 2, 2016 | 11:07 AM
Your video shows the textbook symptoms of coilpack issues
At 150,000 miles, you should have already checked and adjusted your valve clearances at least twice and changed your spark plugs at least once if you're following Honda's minimum recommendation.
Again, my suggestion to you is to: adjust the valves, change the coilpacks, and change the spark plugs - if you haven't already followed Honda's minimum recommendations. Tackling each of those maintenance items just takes you one step closer to the next maintenance item. Just do them all together because it's time to do them, you're experiencing symptoms of those problems, and many others before you have had positive results with those exact items solving their issues in the exact same car.
Given the extreme expense of adjusting valves in Canada (~$1000), I am wondering what are the consequences of neglecting this? And what are the symptoms of valve clearances that are out of whack? Now that I know my issue was entirely due to 1 bad coil pack, I'm wondering why bother adjusting valve clearances (aside from the fact that it's recommended by the manufacturer) if there are no problems/symptoms.
Old Jan 2, 2016 | 09:02 PM
hogwylde's Avatar
I enjoyed this thread.
1. OP posted a problem
2. No bashing in the replies.
3. Opinions were given.
4. Problem was solved.
Old Oct 5, 2016 | 10:45 AM
DanMarino's Avatar
I've got the same idle issue on my 2008 Fit. Just ordered new coil packs and spark plugs from Rockauto last night. Will install it all this weekend.
Old Oct 11, 2016 | 03:54 PM
DanMarino's Avatar
Installed my new Denso coil packs and spark plugs over the weekend. My Fit now idles completely smooth. No bad idle or hesitation on acceleration. The job was very easy to do and I purchased the coil packs and spark plugs from Rockauto. Total cost was around $235. I view this as normal preventive maintenance, like replacing brake pads and rotors.
melissaland
Jul 16, 2022 06:51 PM
melissaland
Apr 3, 2021 08:22 PM
fittenmittens
Sep 2, 2016 06:40 PM
TripleThreat
23
Jan 6, 2015 02:11 AM
1stFit
Jul 31, 2014 11:14 PM
