Radio display flashing off with left turn signal!!!
Old Feb 28, 2015 | 09:24 PM
Illmatic07's Avatar
Hey ladies and gents, I need some help. When I use my left turn signal with the headlights off, my radio display flashes off and on. I checked and I have no bulbs out or anything. When my marker lights and headlights are on the problem goes away. Anybody else experience this or have any thoughts? I do have a side marker bulb out on the right side that I keep meaning to replace, but the timing of that going out doesn't coincide with the timing of the display problem.
Old Mar 4, 2015 | 08:08 PM
bargainguy's Avatar
Wow, that's nuts. Here's what I would try:
1. See if both turn signals are working from the outside, with lights on and lights off. If they're not, or if only one side works, suspect a short / bad relay / etc.
2. If both working from the outside regardless of lights on/off, replace the marker bulb. Couldn't hurt, and it'll bring you up to safety standards anyway.
3. After that, I have no clue, other than your radio is getting some kind of bleedthrough/interference from the L blinker. Radio might be suspect. I think I still have my original 2008 factory head unit somewhere (I replaced mine with an aftermarket unit) if you need a replacement.
Old Mar 5, 2015 | 07:55 PM
Illmatic07's Avatar
Thanks a lot man.
Old Nov 23, 2015 | 03:30 PM
frank438's Avatar
Try wiggling the keys around when the car is running and see if it replicates the problem. I haven't yet had this occur with our Fit, but I had a Chevy that had a similar issue (turn on the wipers and the radio cuts out). Turned out the ignition switch had gone bad. Bad ignitions can have weird symptoms, like the one you describe. If while wiggling the key gently you have the same thing happen, my money would be on ignition.
Old Nov 23, 2015 | 05:19 PM
dwtaylorpdx's Avatar
My fit will turn the radio off for a second if i put pressure in the bottom of the steering column just below the ignition switch, i suspect a bad/loose connection in mine.
nullxposur
Dec 4, 2014 04:54 AM
graphixgurl
Feb 4, 2014 03:34 PM
erin
Dec 3, 2012 03:20 PM
fittr9
Jan 13, 2011 05:24 PM
benfal2001
May 11, 2006 10:32 PM
