P0300 + Other cylinder misfires, only under load.
Old Mar 1, 2015 | 11:00 AM
Buen's Avatar
Hi guys,
I have a 2007 Fit with ~127k km on it. In the last few months I have a taken up a DIY approach to my cars and have encountered a hurtle with my Fit. She has gotten me around for the last 7 years gracefully with not so much as a flat tire or a single CEL.
However recently in the last few weeks I have encountered my first CEL in regards to misfires. I first noticed sputtering and hesitation while idle and in the city (30 - 50 km/hour). I changed each spark plug out for a new one. I used the bosch +4 plugs.
In the city I now don't encounter a single problem. It runs beautifully, you wouldn't think anything is wrong. However the story is different under load climbing to highway speeds.
I get misfire DTC's when applying acceleration reaching around 80-100 km/hr. I get the random misfire, as well as misfires for all the specific cylinders.
I have swapped the current coil packs around without any effect, I can't track down a single cylinder that is giving me a problem, or one that is unnaffected. My next thought was coil packs? But how often do >2 die at one time?
I was hoping you guys could help me come up with some next steps.
Old Mar 1, 2015 | 08:31 PM
mwcten's Avatar
If you're on your factory coil packs, have new spark plugs and are getting misfires, I'd strongly suspect the coil packs and I wouldn't find it too odd that multiple ones could go at once. You could get the OEM Hitachis for $55 (advance auto with a 30% off coupon) each, or if you want a less durable product that would diagnose the problem, you could buy four Rockauto coil pack boots for $10 each. If that's not it, I would probably either try to trouble shoot it with the service manual or just take it in to a mechanic. Also, folks on this forum generally don't advise non-oem spark plugs; only denso and NGK. Sometimes there are problems with other brands.
Old Mar 2, 2015 | 08:25 AM
Carbuff2's Avatar
Why did you install the Bosch +4s when the OE plugs were Iridium?
Alex Smith
18
May 21, 2024 09:56 PM
benjhind
Mar 18, 2023 05:10 PM
frethack
Aug 13, 2017 04:28 PM
bobblebob13
Mar 27, 2013 01:05 AM
Mr_Kunio
Aug 10, 2011 12:33 AM
