14 inches wheel, should i get some 15 inches wheel ?
Old Mar 12, 2015 | 03:00 PM
Phamtastic's Avatar
Just bought a GD3 Fit, the wheels that come with it are 14 inches wheels. It will probably need new tires within a few months. It worth getting 15 inches wheel over 14 ?
Old Mar 12, 2015 | 03:11 PM
Bogdan's Avatar
might as well get 16s while at it. looks awesome, and fits just fine
Old Mar 12, 2015 | 03:14 PM
MNfit's Avatar
Well There is not really any benefit or disadvantage to running 15" over 14". If you think the car would look better with some 15" rims that you like then go for it!
Old Mar 12, 2015 | 04:58 PM
Desmond Lamar MacRae's Avatar
Well there is if you get a wheel that is lighter. Rota wheels are very light and come in many designs and colors. Lighter wheels= less rotational mass= better low end power getting to the pavement.
Old Mar 12, 2015 | 05:05 PM
MNfit's Avatar
Yes very true lighter wheels is a good advantage. Though he could find some 15" or 16" wheels that are as light or lighter the. The 14" wheels.
Old Mar 13, 2015 | 03:28 PM
mwcten's Avatar
It's a balancing act between tire cost, mpg, cornering, vibration damping, and aesthetics. Bigger wheels = more expensive tire costs (both in upfront costs and generally longer life for 14" tires compared to those for larger wheels). Narrow tires and a light wheel+tire weight (generally 14" wheels will give you a lighter/narrower weight; not always) will give you better mpg. Bigger wheels = stiffer sidewalls and better cornering. Bigger wheels = less vibration damping (soft 14" sidewalls will soak up the bumps). And most folks like the look of big wheels better. As with anything in life, you can't have it all. Get a wheel/tire setup that improves what you care about.
Old Mar 13, 2015 | 08:10 PM
h8rsama's Avatar
Hello, and what about the speedo accuracy? How much will it be off?
Im also thinking on going 15 or maybe 16 but it all comes to pros and cons
Old Mar 15, 2015 | 07:53 PM
mwcten's Avatar
re:speedo accuracy, read this for an explanation of how to calculate tire outside diameters. Keep your new OD similar to your existing OD.
http://www.tirerack.com/tires/tirete...e.jsp?techid=7
Fit2009BaseAT
Nov 25, 2014 02:49 PM
Blackbeard
May 21, 2011 03:30 PM
phunklife
Jul 28, 2009 07:32 PM
runbikerun
Mar 11, 2009 01:51 PM
LuxuryFit
Dec 26, 2007 10:05 PM
