3rd and 4th gear do not work
Old Apr 11, 2015 | 02:20 PM
GinoLicious's Avatar
I snapped an axle. Replaced it. Filled up with tranny fluid. Car will not shift into 3rd and 4th gear. 1st, 2nd, 5th, and reverse work. It feels like the shifter is hitting a wall and will not go into 3rd and 4th.
I did not do anything to the inside of the tranny at all. Is this a shift linkage problem or an internal problem? Is a linkage blocked from debris or is it internal and do I have to hit up a transmission shop?
I'm inspecting linkage tonight.
Old Apr 12, 2015 | 11:30 AM
This issue has been resolved.
On top of the transmission. Right under the battery tray there is a bolt. This bolt has a bearing for the transmission with a spring in the bolt as it is a hollow bolt. You need a washer for the bolt as I saw on a Honda parts diagram. I placed the washer on the bolt and boom I got third and fourth back.
Eric Satoshi Harima
Apr 13, 2019 03:28 PM
buttersandpaper
Jun 1, 2016 01:02 PM
ClaytonS15
Apr 7, 2016 08:56 AM
sbualuba
Aug 14, 2009 09:36 AM
blackdot_fit
Jul 14, 2008 05:36 PM
