Engine Serial number
Old Jun 9, 2015 | 10:28 AM
khorton21's Avatar
Can anyone tell me where the engine serial number is on a 2003. Part of the problem is I'm not real sure if it is a 1.5 or a 1.3 engine, although the pics seem to indicate a 1.5 after looking at some of the other posts.
I need to actually make a tracing of the engine serial number in order to get it registered.
Any help appreciated.
Auto transmission, but after decoding the VIN, it doesn't seem to match. Not surprising as I seem to have a JDM Fit that has been (mostly) changed from RHD to LHD. They didn't change the headlights, which still light up the left side of the road well, or the radio/DVD/Nav system, which is entirely in Japanese. Along with all the stickers. No owner's manual either.
210 kPa and 240 kPa listed as the tire pressure, but because of the label I can't tell which is front or rear. Also the wheels have been changed to 15x6.5 with 195/50-15s in place of the original 14" wheels. If I can find some original wheels I'll probably change them back for cheaper and sturdier tires. The roads in the Philippines are not the best.
Otherwise, I need to fix the rear lower valence, coming loose on the left side when I get up above 50 kph. Got the speedo all the way up to 90 on the way to Iba, but that's only 55 mph. Everything else on the car seems to be in very good shape. Need to change fluids but that's normal on a used car.
rahulkentonn
May 8, 2016 08:17 AM
azkikersfit
Feb 5, 2009 06:56 AM
bangdango
Apr 19, 2007 09:22 PM
MVM
Mar 21, 2006 01:32 PM
eddykai
Mar 19, 2006 08:11 AM
