What's behind this panel?
Old Oct 24, 2015 | 09:24 PM
okey0's Avatar
Pic is taken from front of car. In the lower right corner you can see transmission drain plug. I'm curious what's behind the black panel, as I can see some signs of leakage behind it (the darkened area below the panel)
Attached Thumbnails What's behind this panel?-80-image_6c928cc1b4f6f1b825f047bf060bd71630986e50.jpeg
Old Oct 25, 2015 | 06:12 PM
ElanS2's Avatar
It is access to the ring gear/flywheel/torque converter
The ring gear on the flywheel/torque converter.
If your car is a manual Honda calls it "the clutch cover" page 13-7, 2007-8 service manual. If yours is an automatic it is called "the torque converter cover" page 14-233 of the service manual. It looks to me like an automatic.
If the source of the stain comes from the engine side of the ring gear the crank shaft seal could be leaking. If it is from the transmission side look to the transmission for a leak. Are you having to add either engine oil or tranny oil ?
Old Oct 26, 2015 | 08:54 AM
okey0's Avatar
should have mentioned it's an automatic. i have not had to add fluids for at least 9K miles (that is when i last changed oil and a/t fluid). the dark spot is not wet, there have been no drips on my driveway. if its what you suggest, it sounds like pulling the engine would be necessary to repair.
Old Nov 14, 2015 | 07:24 PM
doctor J's Avatar
This is seepage or rather sweat from the rear crank shaft seal; if there is no liquid oil, just "oily dust" it is considered NORMAL!
I have this on my 07 as well.
Old Nov 15, 2015 | 07:43 PM
okey0's Avatar
yeah, i'd say "nothing to see here"----I took the panel off, felt around for some oil, and just got the "dust"
sultanofslide
Jan 14, 2021 11:33 PM
SevereService
Dec 1, 2011 09:13 AM
Dan Gregory
Aug 9, 2011 09:42 PM
hjb613
Jul 15, 2010 07:11 PM
Oofie
Jul 6, 2010 03:04 PM
