Bleeding brake
Old Apr 20, 2016 | 08:53 PM
Hondarian's Avatar
Bleeding brake
Hi,
i would like to know weather required or not to bleed ABS modulator, there's no bleeding screw on it, i'm changing master cylinder last week, after done bleeding, brake not really good, after perform hard brake, brake become more responsive, and then, next day, brake not responsive again, im already check brake component such as master brake, lines, its dry.
Old Apr 21, 2016 | 09:27 AM
Carbuff2's Avatar
Did you Bench-Bleed the master before you installed it? Might have a bubble there...
The ensure that the ABS is bubble-free, you need to invoke the ABS pump. (brake with one side of the car on a gravel shoulder, or wet patch)
Then, bleed again.
Alternatively, you could pay to have a dealer bleed the brakes (their diagnostic system can engage the ABS pump while they bleed). How close is the nearest dealer to you in Malaysia?
Old Apr 22, 2016 | 03:06 AM
Hondarian's Avatar
Then, bleed again.
Thanks for reply,
i'm already bench bleed the master cylinder before installation, and pedal feel firm after bleed on all caliper, but after a few day, it not firm anymore, seem loose pressure or leak somewhere, but i'm check all hoses & caliper, everithing is dry...
Old Apr 22, 2016 | 07:50 AM
Carbuff2's Avatar
Perhaps a rubber brake line hose is failing.
They often look fine from the outside but fail on the inside. ('Balloon' out, it doesn't take much to give a soft pedal)
I'd do the ABS thing first, then if the issue remains, think about replacing rubber brake lines. (Though, Hondas do NOT have this issue as much as other makes)
Also, a pressure or vacuum bleeder might give you a better bleed than brake pedal pumping. Have you tapped on the MC while bleeding? This dislodges air bubbles.
Good Luck!
Old Apr 22, 2016 | 08:24 AM
Hondarian's Avatar
Good Luck!
This is my setup for bench bleeding, yup I'm did a soft tap and lean the mc left and right, brake fluid come without air bubbles
Old Apr 22, 2016 | 10:42 AM
Hondarian's Avatar
I'm confused, I'm not loosing brake fluid, and brake system not keep the brake pressure
Old Apr 22, 2016 | 10:52 AM
Carbuff2's Avatar
But the pedal is firm (not sinking) just after you do a bleed?
Let us know the results after you 'work' the ABS system and re-bleed.
Old Apr 22, 2016 | 11:57 AM
Hondarian's Avatar
Pedal is firm after done bleeding, and after a 1-2 days, brake bexome spongy n not grip, after hard brake (abs activated), brake pedal is grip again
I will try to activate abs and re-bleed, will let you know the result by tomorrow
Hondarian
Sep 12, 2016 06:17 PM
Jimmy101
Sep 18, 2008 06:31 PM
Jimmy101
Feb 21, 2007 08:22 PM
Jimmy101
Sep 14, 2006 01:05 PM
subhamoy@gmail.com
Jun 18, 2005 10:17 AM
