ABS modulator bleeding
Old Aug 29, 2016 | 09:46 PM
Hondarian's Avatar
How to run ABS modulator manually? does anybody done this before? i'm try to bleed brake system using this method, my car brake feel mushy
Old Aug 30, 2016 | 08:29 AM
Carbuff2's Avatar
I've always just invoked the ABS in a parking lot (EG, some wheels on wet pavement, the others on dry). Do this several times.
Then, re-bleed the system.
The dealers can engage ABS with their diagnostic tool, is that an option for you?
PS, I've had good luck with handheld vacuum bleeders such as this MityVac:
Mityvac MV8020 Brake Bleeder - Brake Tools
Old Aug 31, 2016 | 10:07 AM
Hondarian's Avatar
Thanks for the suggestion, i'm use vacuum pump, the problem is, when bleed rear caliper, no fluid coming out, but when depress brake pedal when nipple is open, brake fluid is coming out
Old Aug 31, 2016 | 06:27 PM
Alco RS-1's Avatar
Should we disconnect the battery perhaps? Probably not needed, but maybe a valve is closed at rest? I'm scratching my head too ...
Old Sep 1, 2016 | 10:25 AM
Carbuff2's Avatar
If there is an air bubble in the ABS system, it **should** be "moved on" when the ABS pump is actuated. Since pumping the pedal results in fluid flow, you should be able to get any air out.
Have you bled the system totally, until the brake fluid comes out clean and clear? Or are you just trying to fix the immediate issue?
If you have a mushy pedal despite a total flush and verified there are no leaks, it's time to consider a bad master cylinder...
Old Sep 4, 2016 | 01:28 AM
Hondarian's Avatar
Hi, I try to reverse bleed all 4 caliper using 150ml syringe, the problem is rear caliper cannot bleed using this method, including vacuum bleed, It only can bleed using depress brake pedal & open a bleeder screw, maybe valve inside abs modulator is closed, and im already change a master cylinder few month ago, and bench bleed it,
Old Sep 4, 2016 | 10:00 AM
Carbuff2's Avatar
Might have a bad rubber brake line. A typical failure of the rubber is for the inside to swell, and not allow low pressure return. It will look fine on the outside.
Old Sep 4, 2016 | 09:54 PM
Hondarian's Avatar
hi carbuff2,
i would like to know whether ABS module required reprogramming after doing brake job?
Thank you
Old Sep 5, 2016 | 06:34 AM
Carbuff2's Avatar
I've done several brake replacements and fluid flushes on friend's and my own Hondas, and I've never needed to 'reprogram' the ABS.
Did this issue begin when you replaced the Master? If so there might still be an air pocket inside. I had one car (not a Honda) where the only way I could get all the air out of a new Master was to un-bolt it and tilt it various ways while bleeding.
Old Sep 5, 2016 | 09:46 PM
Hondarian's Avatar
This problem happen after changing brake pad to bendix general CT, it seem like system cannot hold pressure, caliper & hose looks dry, but not sure on steel line, is it worth buying braided brake hose?
Old Sep 6, 2016 | 09:35 AM
Carbuff2's Avatar
^^ usually that's an indicator that you need to replace a caliper. When the thicker, new pads change the position of the pistons inside, they bind (due to rust). The issue is inside the caliper so you might not see it.
Regards using SS brake line, I have those on my sports car (as it sees time on the track) but I think rubber lines are fine for a street SUV. (Same with slotted/drilled rotors.)
Old Sep 9, 2016 | 11:06 PM
Hondarian's Avatar
I think i have a bad/fail abs modulator, after trying heavy braking on high speed 160km/j (100mph), car skid and not hear pumping noise on abs modulator/caliper, but no check engine light and fuse are check, 3 abs fuse in good condition
Old Sep 12, 2016 | 06:17 PM
Carbuff2's Avatar
If you apply brakes REALLY heavily, all the wheels will lock so the ABS system does not come into play. You will NOT hear or feel pumping under those circumstances.
If there is a place in Malaysia that can properly diagnose your issues you could do that.
diesehrl
Aug 2, 2016 01:33 PM
Hondarian
Apr 22, 2016 11:57 AM
Jimmmmmy
Jan 24, 2011 12:02 PM
p1driftfiend
May 19, 2006 07:17 PM
MajBach
Sep 17, 2005 01:31 AM
