My transmission mount is broken, again...
Old Apr 29, 2016 | 10:33 AM
MTLian's Avatar
Hello,
I replace my transmission mount last year with one by the company anchor, it's already all ripped to hell and my transmission is simply resting on the frame and this causes vibrations in the cabin.
I could replace it again and this time pack it with some silicone calking type material or bite the bullet and by the honda one for about 3 times the price... (110$ vs 30$). What should I do? P.S. I don't want to do a racing mod and I'm not looking to stiffen anything up, i just want smooth operation. Thanks for your suggestions!
Old Apr 29, 2016 | 03:56 PM
xxryu139xx's Avatar
if u further harden the mount, u will need to do the others also. there will be increased vibrations putting more strain on the other mounts.
just stick oem, but take a look at the other mounts, they may have gone bad too.
Old Apr 30, 2016 | 01:12 AM
MTLian's Avatar
How can I see the rear motor mount? Is visible from under the car?
Old Apr 30, 2016 | 06:35 AM
xxryu139xx's Avatar
it shud be, its under to the rear of the engine
Old May 1, 2016 | 07:54 AM
doctor J's Avatar
It is easy to see but hard to be done (trench or lift required). The car has to be FLAT with no strain acting on the mounts and on its ride height.
Old May 1, 2016 | 08:32 AM
xxryu139xx's Avatar
no wonder i cudnt get mine to align back. LOL. had to lug it to a shop to get it back on.
Old May 2, 2016 | 12:57 PM
doctor J's Avatar
You can use a tire changing jack to lift the engine bracket to get it in however it has to be tightened as said above.
fit2bking
Jan 27, 2016 01:10 AM
KV43
Mar 3, 2015 03:29 AM
allmotormark
Oct 10, 2014 01:16 PM
mxl180
Sep 1, 2014 11:37 PM
lcq4blackstar
Jul 13, 2011 06:04 PM
