P2647 Car power retarded
Old May 24, 2016 | 12:28 PM
suplexx's Avatar
For a year now I've had trouble with the P2647 code on my wife's 2008 honda fit. For a while it made the idling rough, and had difficulty accelerating at high speeds. After some research, I concluded the engine coils needed changing. I changed them, and it helped the car a lot. The car ran perfect for approximately 6 months.
Now the same code is being thrown, with the same symptoms, just not as severe. I periodically reset the code, and the symptoms go away.
However, when the code is reset, sometimes the car will shut off completely for less than a second, and then come back on immediately. The car loses power, the radio lights go off and everything for just a flash, less than a second. Then the car comes on by itself immediately. This doesn't happen often but seems to only happen when the code is reset.
The oil level in the car is good, and we just changed the oil not long ago. I'm not sure what to do next, and I don't understand why the symptoms leave when I reset the code..
Thanks for the help.
Old May 24, 2016 | 02:15 PM
dwtaylorpdx's Avatar
Check the wire bundle under/ inside the steering column. Its really lame design, and comes loose. Mine would shut off if your knee bumped it.
Old May 25, 2016 | 08:39 AM
Carbuff2's Avatar
That code indicates a problem with the VTEC oil pressure control solenoid.
Here are some past Topics:
p2647 - Unofficial Honda FIT Forums - Threads Tagged with p2647
Old Jun 3, 2016 | 11:56 AM
Jared592's Avatar
That sounds a lot like a bad ground, or even something as goofy-simple as loose battery terminals. I'd check them first just so you're not chasing your tail.
EDIT: As a side note, I'd love if some bro-grammer at Honda stuck a code like this in there for when the car detects you've added a turbocharger to give your car crazy-high power compared to stock. "CAR POWER LEVEL: RETARDED- WEAR SEATBELT AND HOLD ONTO YOUR BUTT"
Old Jun 7, 2016 | 10:04 AM
Jake Fowler's Avatar
Although I have never seen that before I would laugh extremely hard. Just nope too much power dude you are going too fast.
Old May 25, 2023 | 07:03 PM
Zardiw's Avatar
Video of replacing it:
Z
FITDragon
Nov 11, 2021 09:08 PM
nigoleta
Jan 26, 2018 01:41 PM
drkatherine1
Mar 27, 2017 09:52 PM
madvibes
Aug 31, 2010 07:16 PM
