Engine noise - not consistent
Old Jun 6, 2016 | 09:18 PM
mnapuran's Avatar
Any idea? 2008 Honda Fit w/ 115K miles
Old Jun 7, 2016 | 09:09 AM
Carbuff2's Avatar
This only happens at initial start then goes away? We have something similar going on with our '07.
I'd spray water on the serpentine belt to see if that changes the sound. Does the noise vary with engine revs? You didn't try goosing it until the noise was gone, in the video.
Old Jun 8, 2016 | 07:57 AM
doctor J's Avatar
the chirping sound is a glazed spot on the belt or roller
Old Jun 8, 2016 | 11:48 AM
dwtaylorpdx's Avatar
Because the belt system is so low to the ground I noticed mine gets wet quite easily and squeaks like that on occasion.
Old Jun 8, 2016 | 12:32 PM
Jared592's Avatar
Sounds like the belt is either due for replacement (glazed/worn as doctor J hypothesized) or under-tensioned. Unless you've just replaced the belt and it's doing that, I'd say it's time for a new belt. You can confirm by doing the test Carbuff2 mentioned (spray a little bit of water onto the belt when it's doing that and see if the sound goes away).
Old Jun 8, 2016 | 01:31 PM
Sometimes a shot of WD-40 on the Serpentine belt will season the surface and make it stop squealing, temporary fix but if the belt is getting dried out and such it helps.
Old Jun 11, 2016 | 05:21 PM
mnapuran's Avatar
Ugh... that took way longer then expected.
Idler Pulley & Belt Replacement
Old Jun 11, 2016 | 05:48 PM
doctor J's Avatar
This is not a problem as long as problem is solved!
Old Jun 11, 2016 | 06:00 PM
Carbuff2's Avatar
I had the same problem with the first tension pulley I bought. A different source had a better pulley (IMO).
Carbuff2
Sep 12, 2020 12:55 AM
07FitSprt
Feb 24, 2019 09:06 PM
apexanimal
Nov 9, 2013 08:11 PM
myfitfreakacct
Aug 10, 2011 01:51 PM
MNfit
15
May 11, 2011 08:38 PM
