What You Choose, iridium or normal?
Old Aug 13, 2016 | 10:54 AM
rigas520's Avatar
Question What You Choose, iridium or normal?
Hi Friends
I have a honda jazz 1.2 for 2003, and this motor L12A1 need 8 spark plugs.
The question is the normals worth 28€ for 8 and the iridium 65€ for 8 on ebay.
What you use on yours jazz/fit and it worth the investiment of iridium?
This motor are designed for iridium...?
Thank You in advance
Old Aug 13, 2016 | 10:11 PM
dwtaylorpdx's Avatar
On "most" dual plug heads, there is a leading and trailing plug, I've found the trailing plugs do almost nothing, they are there to help emissions, BUT most of them have a shroud around the nose of the plug in the head so they really are not in the combustion chamber, On the old Nissan "Nap-Z" version we would only change the trailing plugs about every third time we tuned up the trucks. YMMV
Old Oct 11, 2016 | 02:44 AM
der Mond's Avatar
Iridium plugs require less juice to produce a spark. Denso Long Life Iridium plugs are just that. You get what you pay for.
Old Oct 12, 2016 | 03:09 AM
gd3~fit's Avatar
Honda OEM
Honda uses Denso long life from factory. See below for part number for Denso.
Attached Thumbnails What You Choose, iridium or normal?-80-img_8502_297fb9da8f2bd05c81cd27920201cc8bf2483be2.png
ansys
Nov 11, 2023 11:41 AM
InsaneGenius
Oct 19, 2015 11:05 AM
Rollerboots666
21
Mar 2, 2015 07:46 PM
wackyflik
Oct 4, 2014 09:11 AM
kylerwho
Feb 8, 2009 07:23 PM
