Power windows/lock issue!
Old Aug 28, 2016 | 11:56 AM
4ester's Avatar
Howdy!
Just bought my wife an 07 fit with 140k on it got a smoking good deal on it. But there are a few issues.. first the rear power windows are unresponsive! (Front work fine) and the power locks do not work at all. Also the radio is asking me for a code!
I figured out how to get the serial # from the radio.. but still need to call honda and see about getting the code.
I checked the fuses for the power windows and locks.. all are fine. The front right headlight was out also, and when I went to change it I noticed the terminal was all burned up!
Burned uo terminal
I'll be fixing that today, but could that somehow be causing a problem with the power windows /locks?!
Any help/ tips are appreciated!!
Attached Thumbnails Power windows/lock issue!-80-20160827_194000_33983f2bb309b88e38abe8284d33072fb6e9b06c.jpg
Old Aug 28, 2016 | 04:45 PM
doctor J's Avatar
Most likely , not.
Old Aug 28, 2016 | 05:00 PM
4ester's Avatar
Any idea what could be causing it?
Old Aug 28, 2016 | 05:16 PM
doctor J's Avatar
One member found broken wire on the door harness (inside of the boot).
Old Aug 28, 2016 | 10:31 PM
Wage Slave's Avatar
The fact that both are not working is likely an important clue. Both could have failed independently but the odds are against that. But yeah, a good place to start is checking the wires into the doors for breaks. It's an obvious weak point because the wires get flexed there.
You'll find a service manual, circuit diagrams and test procedures here:
http://www.hondafitjazz.com/manual.htm
uniguar
Sep 30, 2012 09:05 PM
CombatBaby
Sep 25, 2009 09:43 AM
yoda_97
Jul 28, 2009 01:22 AM
Eddie20
Sep 30, 2005 03:30 PM
