tyres wearing out every year or so
Old Sep 19, 2016 | 03:32 PM
zippy007's Avatar
have gd 2002 jazz,they have a floating suspension,which is causing a lot of wear on the tyres at the front. Have had tracking check every year for the last 2 years,after having a new tyre put on, also needs adjusting,never hit kerbs or gone around corners fast. Has anyone try to replace the top strut plate to a conventional system ie, top plate bolted to mounting chassis.if so what and where do i get the parts from.I'm sure the movement when turning the wheels is taking a different line,causing tyre wear. Especially when on tarmac turning slowly you can hear the scream of rubber.thanks i'm diy mechanic but i do not want to make the suspension worst than it already is.
Old Sep 20, 2016 | 10:17 AM
Carbuff2's Avatar
Wear from turning the wheels (and them turning at different rates) at parking-lot speeds should not cause an excessive amount of tire wear. Look up "Ackerman Steering".
As a DIY, you should not second-guess the Honda engineers. How many miles are you talking? What size tires are fitted on the 2002? Do you rotate your tires on a regular basis (every 7 - 10K miles)?
Pictures of your worn tires would be useful.
Old Sep 20, 2016 | 06:11 PM
dwtaylorpdx's Avatar
Have you checked all the bushings and to top strut bearings? Ball joints? Tie rod ends?
Metalslug
May 8, 2019 01:31 PM
Goobers
Jun 18, 2012 10:55 PM
lnarngr
Aug 25, 2010 01:12 PM
eldaino
Aug 4, 2009 03:56 PM
betahack
Apr 16, 2008 04:40 PM
