Help With Drive Belt
Old Nov 10, 2016 | 11:01 AM
greenmonster2420's Avatar
Hello,
I replaced the water pump on my girlfriends 07 fit this morning. Got everything put back together except I cannot get this new drive belt on. I have tried loosening the two bolts on the top of the alternator and tried to pry it with no luck. I am not having any luck breaking the third bolt of the alternator on the bottom right.
Does anybody have any tips for this?? I do not understand why Honda would make this so difficult to change when they could have just used a tensioner pulley like almost all other cars.
I have it jacked up and the splash shields off. I am trying to get the third bolt through the bottom but no luck.
I need to figure out a way to get this done or I will feel like a complete moron towing the car to a shop to have them complete installing the belt
Old Nov 10, 2016 | 01:59 PM
doctor J's Avatar
How did you removed a belt at first place?
As for the alternator lower pivot bolt use 2 12" extensions and flex joint under socket (approach from the bottom, close to transmission housing)
Old Nov 11, 2016 | 02:54 PM
Carbuff2's Avatar
I used my Wobble Extensions for the lower bolt on the alternator.
They aren't as 'floppy' as a true u-joint for the ratchet so it's easier to get it on the bolt underneath without it turning away from the 'target'.
Harbor Freight has both 3 piece sets and 9 piece sets...
grommet
Apr 27, 2026 09:57 PM
hstoynov
Jan 19, 2020 11:55 PM
lightyear22
Oct 1, 2014 07:47 AM
hazzard
Nov 20, 2013 01:38 AM
running
Oct 26, 2012 12:20 PM
