Clutch not engaging
Old Jan 29, 2017 | 07:27 PM
Angela N Blair Carter's Avatar
Question Clutch not engaging
Just got done changing out factory spring with lowering springs in the front went to back up to turn the car around and back into the garage when half way up the driveway it just stop engaging but was still n gear just changed the clutch with a factory OEM replacement due to the wife is the one driving it. Also there is a steady double beeping sound going off inside the car and doesn't matter what u do it does not stop does anyone know what this problem could be?? Plz help!!
Old Jan 29, 2017 | 07:28 PM
It is an 08 gd3 Manuel trans
Old Jan 29, 2017 | 09:38 PM
ezone's Avatar
Start the engine, Put it in a gear and let the clutch pedal out and rev it up like you are driving it.
What is the speedometer doing?
Old Jan 29, 2017 | 09:59 PM
It's jumping up to 20mph and going back down
Old Jan 29, 2017 | 10:22 PM
ezone's Avatar
It's not a clutch problem. Did you do a clutch job at the same time as you did the lowering springs....or did the clutch job happen long before this?
If you only messed with the springs today....You pulled an axle out too far and the inboard joint has now separated....all completely inside the rubber boot if it hasn't been torn open now. Look to see if one inner CV cup is spinning but the rest of the axle is not.
Or an axle pulled out of the trans....but that's not likely if it's been driven around since the clutch was installed....pulling on struts and steering knuckles makes the situation of an inner joint getting pulled apart far more likely. One or both axles may be affected depending you what you did..
Old Jan 29, 2017 | 10:26 PM
I did the clutch last month but also replaced the CV axles and they were in all the way I didn't even pull them any all I did was pull the strut and left everything else intact It wld still do that!?
Old Jan 29, 2017 | 10:28 PM
I mean I'm kinda stuck right now due to the weather n all and it outside but I'm gonna get on it tmrw and will see Thanx for the info
Old Jan 29, 2017 | 10:33 PM
But also why wld it be making the loud beeping snd
Old Jan 29, 2017 | 10:37 PM
ezone's Avatar
Yes.....when you tipped the steering knuckle to make some room to get the strut(s) in and out, it pulled the axle shaft....and pulling the shaft about 5-8cm out of the inboard CV joint cup is about all it takes to cause the failure.
Good luck. Maybe you can get the axle replaced under warranty?
HTH
Old Jan 29, 2017 | 10:44 PM
ezone's Avatar
Buckle up for safety.
Old Jan 31, 2017 | 01:07 PM
Well i just now got to mess with it again and cv axels are intact and i can change gears without even engaging the clutch at all bout to tear into it some more if any ideas plz let me know
Old Jan 31, 2017 | 01:08 PM
No it wasnt the seatbelt buzzer it was also going off this was entirely different and louder than the seatbelt buzzer!
Old Jan 31, 2017 | 01:13 PM
For the record i am very mechanically inclined! Just putting that out there so u know u dont have to put it in dummy form! Lol
Old Jan 31, 2017 | 02:00 PM
ezone's Avatar
Well you said the speedometer still goes up so that means everything inside the trans is still intact and turning all the way to the differential, the differential drives the VSS so it's all spinning.........so the problem would seem to be isolated to between the trans and an axle, one axle or the other. The most likely places for the failure is at one (or both) of the inner CV joints.
The seat belt beeper is the only one i could think of that beeps a few times then waits for several seconds before beeping again, and it probably only does this while there is a vehicle speed input from the VSS. (going from memory here)
Old Jan 31, 2017 | 02:52 PM
Thank you i will keep you updated
Bounce
Jul 15, 2017 07:28 PM
SammiJo
Jul 25, 2012 06:59 PM
sean5995
Apr 12, 2012 08:41 AM
Previc93
Sep 8, 2009 11:14 AM
CorrodesTheFilm
Oct 21, 2008 07:05 PM
