Low RPM Problem
Old Feb 3, 2017 | 02:11 PM
Nikoloza111's Avatar
Low RPM Problem
https://youtu.be/BMEmnmGCBUo
Guys do you know what is the reason of engine rpm falling down when starting whithout acceleration paddle, or braking? Honda fit 1.5. 2005 year. 67 000 km.
Old Feb 4, 2017 | 01:39 AM
ezone's Avatar
Difficult to judge that without being able to hear and observe what else is going on during the event.
Any fault codes?
Memory dump and idle relearn?
Valve adjustment? I've seen tight valves not only cause misfire codes, I've seen it cause random RPM drop and stalling too.
Old Feb 4, 2017 | 01:43 AM
No fault codes.
Old Feb 4, 2017 | 09:37 AM
Carbuff2's Avatar
Seems as if in your vid, the car was actually MOVING. (10 KPH)
Old Feb 4, 2017 | 09:51 AM
BurntZ's Avatar
+1 on the valve adjustment
Old Feb 4, 2017 | 10:35 AM
Carbuff2's Avatar
OP: Are you letting the clutch out without touching the accelerator pedal? If so, what you are seeing is normal.
The engine computer will 'see' the revs drop, then compensate by feeding the engine more gas.
Old Feb 4, 2017 | 11:29 AM
ezone's Avatar
Check video again, I'm sure it showed the automatic trans PRNDL display on the cluster
Nice yellow accents though.
Old Feb 4, 2017 | 12:35 PM
Carbuff2's Avatar
^^ LOL Not enough coffee yet when I looked. <FACEPALM>
But that begs the question, could the A/C have been cycling on-off when the video was recorded?
mwcten
May 13, 2014 04:53 PM
Marrk
Sep 20, 2013 11:07 AM
der Mond
Jul 3, 2011 09:29 AM
ryu
May 16, 2011 11:38 AM
DrKelso
May 17, 2010 06:54 AM
