Fixed radio -- now vents are stuck
Old Jun 15, 2017 | 12:13 PM
Ben_'s Avatar
My 2 year old decided to stick some coins in our CD player, so I just repaired the unit and removed the coins, following a dependable DIY guide. I hooked up the AC control cables as they were before, but for some reason the vents are stuck on the defrost setting. I confirmed that the cable is actually moving the plastic piece as it did before, but the vents aren't changing. Anyone run into this?
Old Jun 20, 2017 | 09:16 AM
doctor J's Avatar
Need more details:
if you unhook mode cable from lever does a knob have full range ?
does lever goes to the end of it's travel to defrost mode?
If not check for foreign object(s) at air mixing box which is restricting movement of the door
bikerdrumr
Sep 13, 2019 12:19 PM
BraytonAK
Jun 21, 2012 09:32 PM
trashercan
Feb 15, 2010 08:15 PM
braziers
Jul 28, 2009 12:07 PM
BlackFit07
Sep 14, 2006 02:46 PM
