Location of clutch bleeder screw?
I'm looking for the clutch bleeder screw on a 2007 base Fit. I think I found it along a pressurized metal tube on the front-side of the engine, just aft of the lower radiator hose (which has a yellow paint marking at about the right spot):
https://www.dropbox.com/s/oyhklvg2ed...85358.jpg?dl=0
HTTPS://www.dropbox.com/s/r2kua3ppy2...85352.jpg?dl=1
Duralast Clutch Slave Cylinder CS2619 - Read Reviews on Duralast #CS2619
except that where the accordion rubber boot is in the photo, mine has a huge rubber shroud (almost like a sock) which turns 90 degrees and runs down to the transmission. It does have a rubber-capped bleeder valve.
Pretty sure that's it, but I couldn't find online pictures showing the exact location. I had read some descriptions of needing to remove the battery and airbox, or the coolant reservoir, but on my Fit, this is very accessible.
I dunno if I’m crazy or not. But I can’t seem to locates the bleeder screw. My fluid is black and I want to change it since I have left over fluid from bleeding the brakes yesterday.
Is the bleeder screw on the front of the engine in the middle? Behind the fat ass rad hose?
hyperfit
May 25, 2016 05:47 PM
