Clutch not Springing Back??!
Old Sep 21, 2018 | 11:23 AM
gqcpa's Avatar
Unhappy Clutch not Springing Back??!
Hello Fellow Fit Freaks,
I have a 2008 Honda Fit Manual. The clutch is not springing back as usual, but still works. I did a visual inspection and didn't see any leaks and the clutch fluid reservoir is still full. I think it has something to do with the clutch spring, more of a mechanical rather than hydraulic problem. Has anyone out there had any similar experience and can advise?
Thank you
P.S. I can still drive it and shift into gears with no issues..
Old Sep 22, 2018 | 08:17 AM
Carbuff2's Avatar
Can you see if the lever arm (that the slave cylinder pushes against) is returning by itself?
If you can'r see anything on the outside, you may have a master cylinder failing...
Old Sep 23, 2018 | 06:04 PM
gqcpa's Avatar
Clutch not Springing back
Hello,
My problem has been solved! All by itself! I think the clutch is self-adjusting. All I did was sprayed some WD-40 to grease the clutch bracket assembly (Inside) and after a couple of trips, the problem went away.
Flashesbuck
Aug 27, 2019 12:42 PM
Bounce
Jul 15, 2017 07:28 PM
mnapuran
Feb 25, 2016 05:58 PM
Mrksstk
Apr 11, 2014 08:43 PM
Previc93
Sep 8, 2009 11:14 AM
