EPS Replacement
Old Oct 24, 2017 | 06:40 PM
Fit240's Avatar
EPS Replacement
I have been having troubles with my EPS and the problem has been very intermittent. It will be working one day - then later in the day if i turn the car on/off it will shut off. After it shuts off and turns back on it will then go crazy - like it is trying to calibrate. The previous owner had the alternator replaced. What should be my line of attack for this problem? Starting with the easiest/cheapest then progressive to replacing the module/motor. The car is amazing otherwise. I just am not sure where to start then where to go after that. Battery first? Thank you.
fitowner10
Feb 4, 2019 09:23 PM
2nddoorleft
Nov 20, 2018 07:06 PM
Orlando Lara
Jun 18, 2017 12:34 PM
inspire007
Apr 10, 2016 11:23 PM
budro
Jul 25, 2015 11:38 AM
