Won't start after car wash?
Old Oct 16, 2017 | 03:31 PM
fitowner10's Avatar
Hi, I took my car to a drive thru car wash before the weekend, it started well the same day, but after I let it sit for the weekend, this morning it won't start. When I popped the hood, I saw mouse droppings on the battery cover, not sure when that got left there or if that was relevant. The electrical system seems to be in order, all the lights came on when I turned the key, and headlight could be turned on, but no cranking at all (I heard one click, symptoms were different than bad battery situations I had in the past). I measured battery voltage and got 12.6V. What could be the problem? thanks
I got the following diagnostic codes (DTCs), please help! When trying to clear the codes, it says cannot communicate with control unit. I tried jump starting the car, it didn't work, so it doesn't appear to be a battery or alternator problem.
Honda ABS Confirmed DTCs (Permanent)
61-1 MODULATOR-CONTROL UNIT INITIAL IG LOW VOLTAGE
POSSIBLE FAILURE
Battery Voltage Down
Alternator
FSR +B fuse
61-21 MODULATOR-CONTROL UNIT POWER SOURCE LOW VOLTAGE
POSSIBLE FAILURE
Alternator
FSR +B fuse
EPS Confirmed DTCs (Permanent)
11-02 Low/High IG1-terminal voltage (Regular diagnosis)
POSSIBLE FAILURE
Open in IG1 signal harness
Open in +B harness
Battery degradation
ECU Failure
Old Oct 16, 2017 | 06:10 PM
xxryu139xx's Avatar
did it start with a jump?
Old Oct 16, 2017 | 06:26 PM
fitowner10's Avatar
No, it did not start with a jump. It was strange I could pull DTCs but could not do further diagnosis (says can't communicate with control unit) or clear DTCs. The DTCs do appear to indicate a power/voltage issue somewhere?
Old Oct 16, 2017 | 09:08 PM
xxryu139xx's Avatar
get a flashlight and start looking for chewed up wires. probably around the ecu. check the power wire coming from the battery to the car.
Old Oct 16, 2017 | 11:03 PM
fitowner10's Avatar
ouch, i will check fuses tomorrow then wires, thanks. hope the rats/mice are gone now without a warm engine...
Old Oct 16, 2017 | 11:10 PM
xxryu139xx's Avatar
check the main fuses under the red plug on the battery.
Old Oct 17, 2017 | 01:37 PM
fitowner10's Avatar
Unfortunately, all fuses seem to be ok, and no signs of chewed wires... any other ideas? or I might have to tow it to a mechanic... thanks
Old Oct 26, 2017 | 05:59 PM
fitowner10's Avatar
The starter was dead. 8 years, very few start/stops per day...
Old Oct 26, 2017 | 08:04 PM
sucks but glad to hear you were able to find the problem and fix it. now you got another 8yrs of trouble free starting.
Old Mar 5, 2018 | 06:51 AM
bowdizle's Avatar
POSSIBLE FAILURE
Alternator
FSR +B fuse
POSSIBLE FAILURE
Alternator
FSR +B fuse
POSSIBLE FAILURE
Open in +B harness
Battery degradation
ECU Failure
Did you sort this out/ I have similar problem. thanks
Old Mar 5, 2018 | 09:13 AM
spike55_bmw's Avatar
I think he said that the starter was dead but not sure how a dead starter creates all of those codes. Maybe he'll offer more clarity in a reply.
Old Feb 4, 2019 | 09:23 PM
fitowner10's Avatar
Yes, replacing starter cleared all codes
2nddoorleft
Nov 20, 2018 07:06 PM
MagicGuitar
May 11, 2018 11:27 AM
MetalHead88
Dec 29, 2011 07:40 PM
marokero
Aug 8, 2006 12:53 PM
sLiVeRwOrM
Jul 10, 2006 09:51 PM
