DIY power outlet for the rear area
Old Feb 23, 2018 | 12:39 PM
User1's Avatar
Hello all,
I know it's a bad idea to work anything that would drain the battery, but has anyone done this yet? If I was designing this car I would have located the battery on the passenger side, put in a bigger battery and put an outlet in the back, but lots of other stuff was done right.
Old Feb 24, 2018 | 09:35 AM
Carbuff2's Avatar
Just use a fuse tap from the 'protected' side, and run a wire to the rear. (Fit the wire under the doorsills)
If you are planning to use the power point to supply a Lithium-Ion jump-starter, for example, you could use a circuit that is only on with the ignition. (Then, you would only have to worry about the L-I battery causing a fire! )
If you want a constant-on power source for a cargo area light or something,, use one the appropriate circuit.
If its something with a higher current draw, run the (fused) wire all the way from the battery terminal.
Tom Spahr
Nov 7, 2015 05:51 PM
newhere
Mar 20, 2015 06:00 PM
epijimenez
Jun 28, 2014 12:00 AM
fuzzybabybunny
Jan 13, 2011 01:05 AM
Ciggy
Oct 14, 2010 09:52 PM
