Blown fuse?
Old Apr 18, 2018 | 08:57 PM
hqly2001's Avatar
Blown fuse?
My 2004 honda fit had both brake lights and the top brake lights all gonout. Coincidence that they all needed to be replace or i have a blown fuse? If a blown fuse, which fuse is the brakes? I looked at manual and none says brake. Theres a stop/horn, but my horn is still working so that fuse is ok. Help...
Old Apr 19, 2018 | 12:55 AM
ezone's Avatar
Bulbs are cheap. That's a good place to start.
Testing is even better, if bulbs don't fix it.
Old Apr 19, 2018 | 12:30 PM
hqly2001's Avatar
Anyone know which is the brake fuse
Old Apr 19, 2018 | 12:39 PM
ezone's Avatar
Stop/horn is the brake light fuse.
Old Apr 19, 2018 | 05:14 PM
hqly2001's Avatar
So if my horn is working, can i assume the fuse is ok?
Old Apr 19, 2018 | 08:45 PM
ezone's Avatar
Yes.
You can test the fuse if you don't believe it
Got volt meter? Test light?
Manual trans or automatic trans?
If manual, check brake light switch
If automatic trans, the shifter would not come out of park if the brake light switch were bad.
Old Apr 19, 2018 | 11:47 PM
hqly2001's Avatar
Automatic.. i can still drive the car. Car was hit las year and i took it in for bimper replacemeny. Guess it went out between that time and now. Since i can drive and honk, it seems like not a fuse issue and just happens that all 3 lights need to be replaced. Donyou have a website with isntructions to change the brake light and third beake bulbs?
Old Apr 23, 2018 | 08:21 PM
ezone's Avatar
Your owners manual: Index > Bulb Replacement
Miranda Spoox McHenry
Nov 18, 2016 04:54 AM
oneder101
Jun 15, 2015 05:03 AM
over40pirate
Jun 7, 2014 08:35 PM
Fat Ping Cat
Jul 5, 2008 12:34 AM
kitty86
Dec 12, 2005 05:06 PM
