GD3868EW Air Conditioning
Old May 29, 2018 | 11:33 AM
benmaggoswd1's Avatar
Hello All,
I may not be the best user of this forum, so my apologies. Searching air conditioning terms for threads resulted in no hits.
Here's my issue. My '08 Honda Fit (GD3868EW) sport A/C just went out. Im at 142,000 miles. No maintenance what so ever to the AC in ten years. AC went out after driving 20 + miles with cold AC. Then made a stop, shut of the car and no AC on start up.
I'm going to explore the simplest and obvious first. Recharge the freon. Is there a special connection to purchase before I head to Wal-Mart and get a recharge bottle(kit)?
Can i purchase my own leak detection kit? Do I need to be under the car at all?
Thanks in advance.
Ben
Old May 30, 2018 | 04:53 AM
doctor J's Avatar
Visually inspect condenser for damage (look into the holes under bumper); if rock hits it the gas will go out)if no damage is seen, rent a manifold kit or gage to verify that there is a gs in the system(should be about 80 psi with engine off, measured at low side port.
Sometimes a fan control (not the actual fan) fuse blows (7.5 Amp, IIRC) located under dash; this kills a/c and cooling fans , so it needed to be checked right away.
Old May 30, 2018 | 10:40 AM
Jared592's Avatar
Before you go trying to add refrigerant or anything like that, can you confirm the compressor isn't kicking on at all? Run the car with hood open and see if you see the AC compressor start spinning when you have the AC turned on. If it's spinning and you're just getting warm air, you've got a leak. If it's not spinning at all, you could have a seized bearing/clutch (and no problem with refrigerant) OR little to no refrigerant.
Old Aug 3, 2018 | 02:36 PM
OK. So i finally went to get this looked at. AutoZone guy hooked up AC gauges and they showed over-pressure. What does this mean?
Ben
Old Aug 3, 2018 | 02:50 PM
doctor J's Avatar
Ben
did he check the pressure with engine off/ac off?
Old Aug 3, 2018 | 03:14 PM
He checked with engine on and ac on.
Ben
Old Aug 3, 2018 | 04:46 PM
doctor J's Avatar
if both pressures are high the system is likely overcharged or has an air in it
If low side is high and high side is low, the compressor has a cross leak (cannot pump)
if high side is too high and low side is vacuum, the expansion valve is stuck closed
Old Aug 10, 2018 | 03:44 PM
upallnight's Avatar
Ben
What were the pressure readings? Was the engine running and the compressor engaged? If the engine wasn't running, the low side will be high since the compressor needs to be turning in order to drop the pressure reading down.
If the compressor is not engaging the air gap between the clutch plate and pulley might be great enough that the magnetic coil isn't strong enough to pull the clutch plate into the pulley. A rookie mistake is adding refrigerant to a system just because the system isn't cooling. Do a search on some of my previous posts regarding AC repairs.
Old Aug 14, 2018 | 04:40 PM
<if both pressures are high the system is likely overcharged or has an air in it
if high side is too high and low side is vacuum, the expansion valve is stuck closed>
Does this equal new compressor?
<What were the pressure readings? Was the engine running and the compressor engaged? If the engine wasn't running, the low side will be high since the compressor needs to be turning in order to drop the pressure reading down.
If the compressor is not engaging the air gap between the clutch plate and pulley might be great enough that the magnetic coil isn't strong enough to pull the clutch plate into the pulley. A rookie mistake is adding refrigerant to a system just because the system isn't cooling. Do a search on some of my previous posts regarding AC repairs.>
boltaction
Jun 27, 2018 11:21 AM
lief101
Apr 22, 2017 05:34 PM
Jeff Jeffro Tompkins Sr.
Aug 11, 2016 10:58 AM
jjrbus
May 31, 2014 10:05 AM
Grayfox
Aug 25, 2012 08:22 PM
