Issues with power lock and window in one door only
Old Aug 12, 2018 | 01:04 PM
RestlessCA's Avatar
Exclamation Issues with power lock and window in one door only
Hey all, I've just found this forum with the hope you may have some suggestions for me to tackle a rather odd issue, at least I think it is odd.
I have a well loved 2008 Fit, with 346K km on it...still going strong too.
My issue is this. My left side, rear door (driver side) has an issue with the lock and the power window. The power window switch in the door will not make the window open or close. However, if I use the power window button at the driver seat, it works fine. If this was the only issue I'd assume it was the switch but another odd issue at this door is when I use the button to lock or unlock the doors, all the doors work but this one.
I looked at wiring diagrams and checked the fuse for this door and found it is fine (which makes sense since the window works from the driver controls.
I also had the door apart and checked the switch for the window, it is fine. Also looked for any obvious wiring issues, such as a frayed or broken wire, but everything seems fine.
Has anyone ever encountered anything like this and, if so, what do you suggest?
Thanks
Old Aug 12, 2018 | 01:48 PM
ezone's Avatar
Wire(s) broken in the jamb area where they flex every time the door is opened and closed?
Old Aug 12, 2018 | 02:28 PM
RestlessCA's Avatar
Thanks for the thought. I had considered this and don't think this is the issue for the following reasons
1. The rear doors on this car were barely used even though it is high mileage
2. I did check the wires physically and saw no apparent damage
3. The window will open and close using the driver controls. This would not work if there were issues with power to the window in the rear door.
Cheers!
Old Aug 12, 2018 | 03:59 PM
GolNat's Avatar
The common access point for these wires is the door jamb so I would check there also.
Do you have a volt meter?
Old Aug 12, 2018 | 04:32 PM
RestlessCA's Avatar
Yes. I used a volt meter to check power at the fuse and verify the fuse was ok I did not check voltage at the rear door yet... I only did a visual inspection of the wires Next step will be that It's still curious that it works from the front switch and not the back for the window When I look at the wiring diagram they see to be in series... But maybe I'm misreading
Old Aug 13, 2018 | 12:28 PM
One_GD3's Avatar
I'm having similar issues with this as well with a few exceptions. Mines are the rear right door but I don't have power to my windows and speakers.. Door locks still work fine and me troubleshooting it i ran straight power to the window regulator to make sure the motor is still working which it does. So my next thing would be to check if there is a break in the wire somewhere between the main switch to the rear right door.
Old Aug 13, 2018 | 12:33 PM
RestlessCA's Avatar
I may try this, run direct 12V to the window switch to see if the window works. The lock is a pulse so I'm not sure if giving a shot of 12V would be too much
Old Aug 13, 2018 | 02:51 PM
One_GD3's Avatar
Thumbs up
Yea I haven't done much digging around but i suspect there is a broken connection somewhere. When i have time i will further investigate with a volt meter. keep us posted if you find anything
Old Aug 30, 2018 | 09:05 PM
FITTFORME's Avatar
the drivers door makes a loud noise when the power lock activates. I bought it at a Hyundai dealer and they have no clue....they said take it to a Honda dealer. It sounds like the solenoid or actuator is over driving. Any clues guys?
Old Aug 30, 2018 | 09:55 PM
ezone's Avatar
Make sue they accept and pay for the bill first!
If they will pay, let them have at it
Odysseylite604
Feb 4, 2021 08:40 PM
skitchkay
Sep 22, 2016 10:50 PM
Santiad
Dec 8, 2015 08:48 AM
thelate1
Jan 31, 2014 04:53 PM
IN2TURBOS
Feb 24, 2006 04:23 AM
