2007 Honda Fit Clicking
Old Jan 28, 2019 | 03:01 PM
Destiny's Avatar
Post 2007 Honda Fit Clicking
I been having this clicking going on in the engine for a while. I believe is has to do with a bad lifter. Do i need to remove the engine head to remove the valve lifters from a 2007 honda fit?
Old Jan 28, 2019 | 11:37 PM
hotkey's Avatar
^ No lifters on these motors, just cam->rocker arm-> valve stem. You need to remove intake manifold plenum to access the valve cover, then remove valve cover and adjust valve clearance.
Search "valve adjustment" for more info.
Old Jan 29, 2019 | 07:56 PM
Destiny's Avatar
I'm missing a intake valve rocker arm locknut was only able to find one in the cylinder head. Where can i buy these locknuts for adjusting the valves?
Old Nov 21, 2020 | 01:54 PM
pinoretread's Avatar
Destiny, did you ever find a place to order your missing locknut? I'm having the same predicament. Any info on this would be outstanding.
Old Nov 22, 2020 | 03:42 AM
Destiny's Avatar
I had to take them off another honda fit at pick & pull to replace them.
Old Nov 22, 2020 | 03:38 PM
Thank you so much for the reply! Looks like I'll have to go scavenging.
Old Nov 23, 2020 | 04:18 PM
GAFIT's Avatar
https://www.hondapartsnow.com/genuin...205MT&filter=()
Looks easier to just order or go to a dealer.
FitCrazy80
May 7, 2022 03:07 PM
amberd03
Aug 20, 2017 11:57 AM
sunnyday
May 27, 2017 09:18 AM
richardwhite
Sep 4, 2014 09:43 PM
