Takeda CAI
Old Jan 21, 2012 | 04:01 PM
thc888's Avatar
Thank you - agree that the hizz sound makes it really cool as I have it in my CRV, and the acceleration would be a big gain. Could be my next mod project. That being said, any thought on stronger rear sway bar?
Old Jan 21, 2012 | 08:29 PM
thc888's Avatar
Just look into this more, the posted CAI only applicable to 09-11 FIT MT. Does anyone have experience of this for a 09 FIT base AT? Just curious about how an intake will have any affect on tranny? And how about this one which does not mention either MT or AT, and 11 bucks cheaper?
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old Jan 22, 2012 | 02:52 PM
loders's Avatar
Looks awesome! About how high off the ground does the lowest part of the filter sit? The CAI on my RSX-s is about 8in off the ground and I cringe whenever I see a flooded street. I'm thinking the Takeda sits well above that but would like to know from actual owners. Thanks!
Old Jan 23, 2012 | 11:10 AM
2012FitTexas's Avatar
I would have to measure to get the actual inches. But it sits right under the battery
Old Jan 25, 2012 | 04:42 PM
loders's Avatar
I just installed mine and it sits much higher than in my RSX-s. I don't think hydrolock is an issue unless I end up driving in 2' of water.
Old Feb 4, 2012 | 08:25 AM
LeAJazz's Avatar
Hey do you guys know whether the takeda intake will fit on A/T fit's? Most sellers on eBay have a note: "manual transmission only". why is that?
Old Feb 9, 2012 | 09:40 PM
loders's Avatar
I believe it is because the automatic transmission sits farther forward than the manual transmission.
Old Feb 14, 2012 | 10:36 PM
NewFitGuy09's Avatar
So this intake will not fit AT???
Old Feb 15, 2012 | 12:44 PM
thc888's Avatar
I looked into this as many of us with the same question. This CAI design has a long intake tubing goes down from the intake and loops under the battery. For the AT model, the transaxle takes up too much room for the intake tubing to fit in, unless you can mod it. However, the Fit's engine comparment does not have too much room to fit the cone filter design. I am thinking about using a flat K&N cone filter and a short neck tubing without loop downward. Any advice out there?
Old Jun 18, 2015 | 11:02 PM
ALPHAEC7's Avatar
Takeda in water
Well recently installed the intake and i just got home from driving in one of the worst storms I've ever driven in. Puddles a few inches deep, and i had no problem. It made me wince everytime i hit a big puddle. Especially when if hydroplaned (run the 205 width tires, helps a ton). I babied the throttle, and kept it in low revs to prevent it from sucking water. however i also have an injen hydroshield on it. So i say its fine as long as youre careful and put a hydroshield on it and replace it every so often (the water resistent coating wears off after a while, or at least thats what it said on the package).
Old Jun 25, 2015 | 05:21 AM
mtheo31's Avatar
I also have the Takeda. Didn't notice any significant mpg/hp gain but I really like the sound.
Old Jul 20, 2017 | 11:17 AM
  #32
Vilot's Avatar
Will the Takeda CAI fit the GE6(L13)?
Fatbrando
Jun 9, 2012 09:16 PM
Stay
Feb 28, 2012 08:30 PM
tanger
Mar 13, 2010 12:10 PM
jimmyq71
May 6, 2009 08:33 AM
scott_b
Jan 28, 2008 07:11 PM
