The 51R battery is the better choice for the Honda Fit
Old Feb 20, 2026 | 01:02 PM
  #121
TDHofstetter's Avatar
Originally Posted by bobski
Chasing is using a tap to remove debris (corrosion included) from the threads. The tap engages and follows the threads, it doesn't cut new ones.
UVA black-body emission starts above about 2700° Celsius. If stuff in your engine bay is getting that hot, your car has more important issues that need addressing.
"Chasing" generally involves following extant threads that have been damaged or filled with rust with a threading tap. It's re-tapping. There is no other form of re-tapping.
The reference to UV degradation has nothing to do with black-body radiation. It has to do with plastics and other substances breaking down on exposure to oxygen in the presence of ultraviolet light.
Old Feb 23, 2026 | 10:47 AM
  #122
bobski's Avatar
I have never heard of "re-tapping". If the thread form is damaged enough that a tap can be used again to remove additional material, there will be voids left in the resulting thread form. It will still be damaged afterwards, and thus has not been tapped properly.
Chasing is removing foreign material from the existing thread-form. Chasing is not tapping (cutting new threads in a drill hole) or "re-tapping".
Where would UV light come from in an engine bay? The only sources I can think of are spark plugs or HID headlight bulbs, and they're all contained and/or directed away from the engine bay.
Old Feb 23, 2026 | 11:03 AM
  #123
tapping
Chasing is never performed with a tap which exactly matches the original tap; it will always (100%) be either larger or smaller than the original. More than 50% of the time the chasing tap is larger than the original tap (because intelligent mechanics and other repairmen never buy interference-fit taps). Therefore, the tap used for chasing either cuts or forms. Either is "tapping".
But you do you. I'm fine with it.
Where would UV light come from in an engine bay? The only sources I can think of are spark plugs or HID headlight bulbs, and they're all contained and/or directed away from the engine bay.[/QUOTE]
The engine bay is washed with UV light, just like the rest of our world is. Sunlight and skylight reflected off the ground, off puddles, off snow contain oodles of UV because UV reflects just like visible light does.
Really.
But - again - you do you.
erichyung
Mar 16, 2026 04:11 PM
Jensen Healy
Dec 6, 2019 02:54 PM
James Butler
Dec 2, 2018 08:51 AM
dman
Sep 15, 2016 08:39 AM
CitoFit
68
Jun 18, 2015 10:38 AM
