Anyone try a HPS Short Ram Intake?
Old Jul 15, 2015 | 02:59 PM
  #41
Fit Hybrid RS 2012's Avatar
C
ok.today i installed HPS SRI.i feel the difference and sounds so nice.but when in sport mode,on heavy paddle,the CEL came.any ideas what should i do? may be not full paddle in 1 st week so the ECU learns ?
Update: i did surf the net and than did 'Idle learn' procedure.it is starting the car after ECU reset and let it idle for 3 minutes.than turn off for 1 min.than again start for 3 minutes.
i did it and the CEL never came back.i drove it like crazy it sport mode but NO CEL
so any one getting CELs from after market intakes (not D.I.Y intakes),do this 'Idle Learn' procedure and you will be fine
Old Jul 22, 2015 | 08:12 AM
  #42
failed
the CEL comes again.so it proves that GE8 ECU needs tuning.1st buy any tuning solution than buy addons.
i cheched every connection.they are all tight.
may be because i have hybrid which has CRZ engine.may be i would have ordered CRZ intake....
do other GE8 users have this problem?
Old Jul 27, 2015 | 01:48 PM
  #43
running rich!
i checked the CEL with scanner and the error says' fuel system too rich'
funny.i thought it must be running lean due to more air.but its the opposite.any suggestion?
Old Jul 28, 2015 | 12:32 PM
  #44
Myxalplyx's Avatar
P0172 - System Too Rich
Old Jul 28, 2015 | 01:59 PM
  #45
Originally Posted by Myxalplyx
Thanks for sorting that out for me.any way i have put back my stock intake just to test out whether its the HPS SRI casuing it or other things.i will confirm after few runs.LOL the car runs so smooth with stock intake.with HPS some time it jerked in very low RPM's.with HPS my fuel mileage was down(e.g.. from 20Km/L to 14 Km/L,highway from 18 to 14.) i think that plenum in stock air intake is very important which most short rams lack
Old Aug 3, 2015 | 05:32 AM
  #46
More than 400 Km with OEM intake and no CEL. so this confirms that this not for Hybrid versions of GE8.may be after a tune it can be used.
Old Nov 28, 2016 | 12:33 PM
  #47
lokomaika'i's Avatar
Originally Posted by oufink
Update: I installed the HPS intake last week and I'm a fan so far. No mileage number to report yet. My butt horsepower rater is happy. Mostly I wanted a little bit more sound, but only when I was pushing it and that's exactly what I got. No additional sound while cruising on the highway, thankfully. It's a nice sound when you are full throttle, or over about 3,500 rpm. Plus it looks good (not amazing) in the engine. I'll post some pictures soon. I ended up googling coupon codes for the product and bought it for $150 including shipping and the K&N air filter. Took about 1 hour to install.
Can you help me install mines? First time I'm installing anytging on a car and I bought it used for $115 but no manual. Ik you gotta remove the crank case vent hose and the coolant hose from the stock air box but where do I put them on the short ram?
Old Nov 28, 2016 | 10:03 PM
  #48
There is no coolant hose on airbox,its on throttle body.leave that as it is.but i think factory bracket holds both crank vent and that coolant hose to throotle body so that why you are confused.i think i used a small hose to directly connect coolant hose.and for crank vent hose there is a place in short ram intake for that
Old Nov 30, 2016 | 01:03 AM
  #49
So the crank case vent hose goes onto the sri after its installed. Does the coolant hose go back in the same place on the tb? And did you have to replace any coolant?
Old Nov 30, 2016 | 03:23 AM
  #50
yes crnk vent hose goes to sri.and coolant hose to its place.no coolant will come from it.so no need for coolant replace
Old Nov 30, 2016 | 04:27 PM
  #51
Ok. Thanks. I was watching the install video for the k&n sri and they do I it pretty fast and it through me off when they said I might have to replace coolant lol. But thanks for your help!
Old Jun 12, 2017 | 02:53 PM
  #52
TougeMonster_GK5's Avatar
I have my KNN drop in for sale if anyone is interested. I used it for less than 800 miles. Still in the box. $25 shipped. Still perfectly clean and oiled.
message me! Im interested
Old Jan 9, 2019 | 06:26 PM
  #53
gnuelniloc's Avatar
Deleted post
Old Jun 8, 2024 | 09:48 PM
  #54
Johnm taggart's Avatar
Get a unvrsl hood scoop and hps small ram intake system
I'm just joining this forum (Been lurking for a while) and am interested in intakes. This seems simple enough. Please report your findings. I'm actually wondering if this will fit a 2015 Fit. I plan on adding pieces to it to make my own version of a cold air intake.
get a unvrsl hood scoop 17inch from Amazon and hps small ram intake system honda fit sport or jazz
Old Jun 8, 2024 | 09:50 PM
  #55
Handa fit
Get a unvrsl hood scoop and hps small ram intake system honda fit it should get 15 to 20 more horsepower
Old Jun 9, 2024 | 09:42 AM
  #56
NWCH's Avatar
Your first post here is absolutely worthless. smh
beingmesince93@yahoo.com
Jul 16, 2012 04:26 PM
0021
Feb 2, 2010 06:57 PM
Fitamusprime
May 1, 2009 08:20 AM
jaydubz79
Feb 17, 2009 11:04 PM
ride_the_pony69
May 22, 2007 11:24 PM
