Going turbo
Old Sep 16, 2016 | 01:28 AM
  #101
paulsheer's Avatar
Well after endless searching it seems you need (summitracing.com) CP-Carrillo SC7039, SC7038, or SC7037, depending on your bore size; as well as "K1 Technologies H-Beam Billet Connecting Rods HH5865AAWB4-A"
There do not seem to be any other performance pistons/rods
Together they are $1k *gulp*
Old Sep 16, 2016 | 01:39 AM
  #102
BMW ALPINA's Avatar
If I am not mistaken, there is HKS piston kit available and pretty sure either someone here had ordered a Mahle piston or you should be able to order from Mahle...
Old Sep 16, 2016 | 09:48 PM
  #103
paulsheer's Avatar
This looks like the cheapest. Exactly 1k total and it includes the rings:
Honda FIT Rods Honda FIT Performance Parts K1 FIT Connecting Rods
This turbo looks about right. I like the idea of OEM-style 'cos replacements are easy to get.
Audi S3 BAM 1.8L K04-023 06A145704Q 53049880023 Turbo Turbocharger
Here was the other one I was thinking. (Generic, not really Nissan.)
GT28 GT25 GT2871 GT2860 T25 T28 SR20 CA18DET Upgrade 400HP Turbo Turbocharger
(maxpeedingrods.com is a chinese distributor.)
just making notes here: ebay.com/itm/140721411737 http://www.ebay.com/itm/GT2052-Turbo...-/252451741457
Old Sep 19, 2016 | 01:32 PM
  #104
allTRACway's Avatar
http://www.wiseco.com/Catalogs/Autom...eteCatalog.pdf
page 72 for pistons
2009 Honda Fit 4 Door Hatchback Sport Engine Internals
for pistons and rods
The only thing aftermarket I haven't found for the L15A7 is a crank
Old Sep 19, 2016 | 01:41 PM
  #105
arrow_runner's Avatar
Are there sleeves for the L15? Or do we need them if we're overboring?
Old Sep 19, 2016 | 02:12 PM
  #106
allTRACway's Avatar
https://www.goldeneaglemfg.com/index...page=page&id=1
according to that link they company there can sleeve
Old Sep 19, 2016 | 02:57 PM
  #107
paulsheer's Avatar
what is the difference between this sleeve and stock?
Old Sep 19, 2016 | 03:57 PM
  #108
allTRACway's Avatar
I am reaching out to them to make sure they can still do it, what the price is, and what the difference is and what the HP is they warranty to. I will keep everyone informed on the update.
Old Sep 19, 2016 | 06:18 PM
  #109
allTRACway's Avatar
Called them, they can source all the parts needed but are not willing to build a L15 and put their name on it! The sleeves are complete cylinder replacements and are made to "have them tiny little engines boosted the heck out of them" so I asked if I put 20 lbs to it and used it as a daily they said it would hold all day and be just fine. The company also doesn't warranty any of the work they do.
As far as needing sleeves these being aluminum blocks are sleeved already, and on youtube theres cars pushing 300+ almost 400 without build lists, if we could get ahold of one of them crazies we might know if a sleeve is even needed for those kind of numbers.
Another question to ask I guess is what kind of power are you looking for?
Old Sep 19, 2016 | 06:58 PM
  #110
paulsheer's Avatar
I am looking for double the HP -- so 230 HP
Do I need forged pistons for this? Or just increase the ring gap?
I read above that better rods are needed. These are cheep compared to the $650 for the forged pistons.
I do want something that will last BTW :-P
Old Sep 19, 2016 | 08:58 PM
  #111
kylerwho's Avatar
spoon fed
If you search out fits in Thailand they are running 400whp on stock sleeves so I wouldn't worry about that.
A cheap alternative to forged pistons is the 2016 civic turbo pistons. The engine is dubbed the L15b7 and has the same piston size as the l15a motors.
Then get some K1 technology rods and you will be good until about 320whp roughly.
Old Sep 19, 2016 | 09:08 PM
  #112
paulsheer's Avatar
that's great info - thanks!
what compression ratio is that piston? (I plan to run 92 octane and an intercooler.)
will I need an air pump to a air tube cat to pass emissions???
all the performance mods I've read about eliminate one cat.... but how do they pass inspection??
(At my testing station there is no "visual" check --- they just want your smog numbers low --- I'm not going to cheat --- I do want *actual* low numbers -- ha ha)
Old Sep 20, 2016 | 12:07 PM
  #113
kylerwho's Avatar
spoon fed
Compression will be around 10:1. Don't have exact numbers since I don't have the cc numbers of that piston.
To pass emissions add a metal cat after the turbo is about the best way to do it.
Old Sep 20, 2016 | 10:50 PM
  #114
GE8FTW's Avatar
ok everyone have not been on here in a while but I ordered my AEM fail safe gauge wide band/boost gauge and vibrant 2.5 inch resonator getting it next week and then planning on installing it next week 2.5 inch exhaust turbo back and then when ktuner release's speed density plaining on pushing her up to 7psi. and i got a greedy DT muffler so should sound good. huge shout out to heel toe auto on helping me get all these parts to make this build happen check them out heeltoeauto.com
Old Sep 21, 2016 | 06:28 PM
  #115
jmsplitfyre's Avatar
Subscribed!
Old Oct 4, 2016 | 12:35 AM
  #116
VerneTheFit's Avatar
Could this sort of turbo build work with an auto gearbox?
Old Oct 25, 2016 | 10:30 AM
  #117
BMW ALPINA's Avatar
Hi GE8FTW,
How are you?
Did you ever get the Dynochart from Church tuning?
If yes, please kindly post it here.
Also some of member here who use K-Tuner with Sprintex had been experiencing some error code lately (check the sprintex thread this past few days).
Did you experience some error code too?
It's colder weather now... any affect on your car and tune?
Thanks
Old Oct 26, 2016 | 05:25 PM
  #118
Boostedtaco's Avatar
Hey. How is your MPG? Mine is 25 cruising at 75-80.
Old Dec 16, 2016 | 12:45 PM
  #119
DanDRuiz's Avatar
So nearly 3 months since last post.... any update on how the turbo is going? Numbers?
Old Jan 15, 2017 | 10:12 AM
  #120
GE8FTW's Avatar
ok everyone i ordered a motor should have it soon going to fully build it and port polish the head and run a bisimoto cam stage 2.4 ad i want a borg warner EFR turbo.
