2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
Turn Signal Bulb?
Old May 19, 2010 | 01:00 AM
thefit09's Avatar
Turn Signal Bulb?
Does anyone know what type bulb I need for the rear turn signal? Is it printed on the bulb? In texas turn signal bulbs can be red or amber in the rear, and I am looking to get a red LED replacement. Would this fit? Red 7440 T20 Blinker Turn Signal LED Lights Bulbs L34: eBay Motors (item 130366027777 end time Jun-09-10 20:49:58 PDT)
Old May 19, 2010 | 11:10 PM
thefit09's Avatar
anyone know their bulbs around here?
Old May 19, 2010 | 11:59 PM
hayden's Avatar
Based on what I know - that should work. If you are going to go with something out of the ordinary that people are not used to seeing, then make sure those suckers are bright. Turn signals are one thing I am weary about messing with, and in your case, the LEDs need to be super reliable, otherwise you are setting yourself up to get rear ended. Just some things to think about.
edit: oh yeah, those particular ones you posted are not going to be very bright. Check out a reputable site like autolumination and get some SMTs.
Old May 20, 2010 | 02:43 AM
koolkevin1107's Avatar
Rear turn signals are 7440.
U could go with those ones on ebay, but remember they are forward facing LED's only, so its not gonna be as bright as all direction facing led's. I'd recommend these:
Tail Light Brake Light Turn Signal LED Bulbs
Go down til u see the 15led ones selling for $7.99 each. These are the same type of design u have chosen, however it comes with side facing led's to fill out the reflector area.
If ur a real baller, get the SMT Tower III for $12.99. There is a bigger amount of LED's and it'll really be bright!
Oh btw if ur gonna change ur turn signals to LED's, u gotta get a load equilizer to prevent it from hyperflashing.
LED Flashers Blinkers Resistors Load Equalizers for Turn Signal Replacement Bulbs Rapid Flashing Fix
Go down til u see the 3 OHM DELUXE ALUMINUM ones. They are $8.99 each and u need 2 of them.
Or u can get some from ur local pepboys or kragen, they usually sell them.
Old May 20, 2010 | 02:47 AM
thefit09's Avatar
thanks koolkev! I read about resistors and kind of gave up because I had no idea what I was looking for. You just pre packaged it for me so I think ima go for it.
Old May 20, 2010 | 06:10 AM
xRiCeBoYx's Avatar
A 10W 10Ohm wirewound resistor from radioshack works as a load resistor. I have some on my civic for my front turn signals.. Only downside is you gotta get creative on how to mount them. 3M double sided tape doesn't work because they get kinda hot..
Only $2 and they come in a pack of 2.
Old Jun 21, 2010 | 11:16 AM
Bleemv1's Avatar
Hey guys,
my first post I've got a Taffeta White 2009 VTi-S (Honda Jazz as I am Australian )
Just looking to replace my turn signal bulbs to 'chrome' indicators. So far I know that the rear bulbs are 7440 T20 Wedge, the front signal bulbs are ??? (7507 bayonet?) and the side signal bulbs are 194 T10 Wedge?
Could someone confirm these bulbs? I'm looking to get bulbs from autolumination.com (superlumination.com?)
Thanks in advance
also, what advantages do the LEDs have over normal bulbs? they seem a bit more complicated so set up?
Old Jun 22, 2010 | 02:50 AM
Bleemv1's Avatar
well I found that the front signal bulbs on my car are also T20 Wedge. All good They're all ordered.
Old Mar 7, 2011 | 03:44 PM
DizzleDj's Avatar
Originally Posted by bleemv1
hey guys,
my first post i've got a taffeta white 2009 vti-s (honda jazz as i am australian )
just looking to replace my turn signal bulbs to 'chrome' indicators. So far i know that the rear bulbs are 7440 t20 wedge, the front signal bulbs are ??? (7507 bayonet?) and the side signal bulbs are 194 t10 wedge?
thanks in advance
also, what advantages do the leds have over normal bulbs? They seem a bit more complicated so set up?
can anyone answer he's question? I want to know too:d
Old Mar 7, 2011 | 03:51 PM
spreadhead's Avatar
Old Aug 5, 2012 | 06:44 PM
olias's Avatar
Originally Posted by spreadhead
That's awesome. What is this google you speak of...? Sorry. just messing with you. I've done the same thing more than once.
Old Aug 9, 2012 | 05:36 PM
BlueBoogers's Avatar
Way to bring back a 17-month old thread
wagonsrulemyroad
Jul 31, 2014 01:38 PM
lovebiters
Feb 20, 2014 09:14 PM
sav_fitatsos
Oct 20, 2010 11:02 AM
kakrohn
Apr 5, 2010 07:18 PM
EXWRX
Dec 4, 2007 12:52 PM
