DIY: Focal 165V1 installed using factory mounts
Old May 26, 2010 | 10:24 PM
NipponFit's Avatar
This is my first DIY so any feedback is appreciated!
1. Remove the screw by the handle
2. Pry the cover off to reveal the 2nd screw
3. Unclip the power window harness
4. *NO PICTURE OF THE DOOR PANEL* pry off the door panel then lift it up and out but be VERY careful because the door handle is still connected. Unclip the 2 door handle mechanisms
5. the speaker is only held on by one Phillips screw. once unscrewed, lift it up and out then unplug the speaker wire harness
NOW THE FUN PART!
6. Break off the plastic bits
7. rip out the "magnet"
8. Rip out the connector
9. Rip out the speaker!
10. This is what you should be left with after all the breaking and ripping
11. Time to do some more breaking and ripping! break off the inner layer
12. Once you're finished you should have something like this *note that i left the bottom piece (got lazy and it seemed like it was going to be a pain to deal with)
13. Now time to saw off this area so you speaker can sit flat
14. Now that you're finished, it looks like this!
15. You can now install your speaker (I suggest pre-drilling holes first, made my life easier.
16. Now the final step before reinstalling everything back. Use a box cutter to take off that plastic that is on the door panel so it doesn't get in the way of the speaker.
Installing the tweeter was simple, I just drilled a 45mm hole into the panel. I just used the location that had a circle with a cross in it.
You'll notice the tweeter sticks out a bit, I could've moved it up for a cleaner install but this area was best so the tweeter pointed to me slighly.
Over all this was an easy install. Hope this helps someone else out there.
Old May 27, 2010 | 12:44 AM
accordguyintake's Avatar
awesome! how do the Focals sound? i was VERY close to getting the Polyglass also but i went with Hertz HSK 165.4s in the end
Old May 27, 2010 | 10:54 AM
NipponFit's Avatar
Pretty good for the money. changing the head unit, the sound was already better, but after the focals went in...a MUCH better improvement.
Bass was pretty good too. I don't have any idea what the other guys on the forum are talking about when they say the focals don't have that much bass. This is mid bass we're talking about, if you want real bass then you're looking for a sub!
As a driver, the sound is great. I hear it all!
As a passenger, the sound on the driver side is a bit drowned out due to the fact the driver is there. That is positioning of the tweeter though.
Old May 27, 2010 | 11:45 AM
Daemione's Avatar
Very cool. Any shots of how/where you mounted your cross-overs?
I'm gearing up to install some elemental designs components in my GD. Ran all the wiring & installed the amp last summer, but got bored with the project. But the mod bug has caught me again this spring . . .
Old May 27, 2010 | 12:02 PM
NipponFit's Avatar
No real shots on where I mounted the cross overs yet. I just mounted them with some double sided tape onto the outer door panel. I'll take a picture when I run the wires and amp.
phenoyz
Nov 1, 2010 08:51 PM
mole177
Mar 6, 2009 11:46 AM
sy11580
Dec 20, 2008 08:20 PM
badself
Sep 22, 2008 11:32 PM
apple
Apr 17, 2007 12:27 AM
