Sound Deadening Project (Lots of Pics)
Old Apr 24, 2011 | 08:50 PM
ebouwman's Avatar
So why didn't you put the ensolite in the middle up front? Just too much cost i guess?
I thought i'd look into this as i did my first road trip and i really noticed the noise, that and my girlfriend complained when i turned up the stereo loud enough to hear the music.
After a whole day of travel the sound really wears on you as well, especially with almost no sound insulation in the fit (as much as i love the car)
I think if i do this i'll do it in chunks, front, back, doors, separately as i have the money/time to do so. Either that or enlist the help of my brother in exchange for beer XP
Also, do you have a rough idea on the square footage of the floorspace? Trying to price this out in my head...
EDIT: Sorry, read a little more and found my answers more or less...
Old Apr 25, 2011 | 09:28 AM
jcuecker's Avatar
ebouwman
I would estimate around ~45sqft of each material for the doors, trunk, hatch, & floor. Probably a bit less of the CLD depending on the coverage you plan on applying.
Doing it in stages is probably a good idea. The fits interior pops apart pretty easily but it is time consuming. It also gives you a better sense of the kind of specific noise reduction you get from treating each section.
Before attempting the project you should also try to identify the specific noises that bother you at highway speeds. the noise from wind, road vibrations, and passing cars/trucks can be reduced quite nicely. The fits whiny engine, on the other hand, is more difficult to quiet up (unless your willing to pull the complete dash).
Old Apr 25, 2011 | 10:07 AM
ThEvil0nE's Avatar
nice work.
my last install was for my 99 accord (SQ setup that cost me in the 5K) after I used quickroof... I'll never use any of those expensive snake-oil-brand dampening materials again.
Old Apr 25, 2011 | 08:40 PM
ebouwman's Avatar
Originally Posted by thevil0ne
nice work.
My last install was for my 99 accord (sq setup that cost me in the 5k) after i used quickroof... I'll never use any of those expensive snake-oil-brand dampening materials again.
5000????????????
Actually looking at the weight of the MLV i might have to see about a local option for that, also i have to consider that i'll be shipping this cross border most likely...
And i'm assuming you got your CLD and MLV from Sound Deadener Showdown?
Old Apr 28, 2011 | 02:07 PM
jcuecker's Avatar
I got the CLD from Ramm Audio and I purchased the the CLD from a company called 'Super Soundproofing Co." 44sqft for $49.60 + $57 Shipping
Old Apr 28, 2011 | 03:04 PM
ThEvil0nE's Avatar
Originally Posted by ebouwman
5000????????????
this quick roof...
Quick Roof™ instant waterproof repair for regular and rubber roofs
yes, my system roughly cost me 5K. I was using 3 amps which were made by ZED (US made of course), audicontrol processors, unpowered burr-brown alpine hu which I later added the clarion autopc, mbq seperates/drivers (pre-maxxonics crap), later upgraded to a/d/s, matching quality interconnects and wires... which I installed myself. I lost interest when my car was stolen (yes the entire car) and 2 of the amps was taken. I managed to track one same amp on ebay a year later... still have not replaced the other until I totaled my car just 2 years back and decided to sell everything.
I am now keeping myself away from the ICE scene
Old May 2, 2011 | 12:32 AM
djmnsf's Avatar
Do you know of any service provider who will DO the soundproofing work? In the San Francisco Bay Area? Can it be a tinting, stereo system installer?
Old May 2, 2011 | 03:27 PM
smeister's Avatar
Good stuff man! That MLV must be doing its job nicely...wish I had some MLV in mine hehehe
Old May 17, 2011 | 02:40 PM
BlueBoogers's Avatar
Come do mine. I'm too lazy! Haha
Old Jun 22, 2011 | 12:57 AM
danlisahall@comcast.net's Avatar
Great write up, mega informative. I tried to something similar in my Del Sol, using dynamat foil backed type product alone & was not impressed. This looks much better.
I am not afraid of removing the seats, plastic panels in hatch, but more relucant to remove door panels. How difficult was it to get the door panels off? Was there a factory applied sheet of plastic on the inside of your door panels? If so, did you replace that? Its unclear to me what the roofing product was -- looks like thin sheet metal, but probably not. What tools did you use?
May be a winter project for me.
Old Jun 22, 2011 | 09:24 AM
jcuecker's Avatar
I wouldn't worry about taking off the door panels, its very easy on the fit. You basically pop off the cover over the armrest and remove a screw, remove the screw in the latch, and then stick a little pry bar between the door panel and pry up to remove ~12 retaining clips around the edge of the panel. There is a plastic sheet covering the big holes in the door frame. Yes the metal material I used whats called "roof flashing" and is available at Lowes/Home Depot. Its pretty thin and can be cut with heavy duty shears.
Really the only tools you may need for the job are: small pry bar, Phillips screw driver, heavy duty shears, box cutter, socket wrench (to remove seats).
Old Jul 31, 2011 | 02:08 AM
  #32
fitblitz's Avatar
Amazing write-up, this is exactly what I was looking for.
I'm going to use this as my step-by-step guide
What do you use to stick the MLV to the Ensolite?
Old Jul 31, 2011 | 10:05 AM
  #33
jcuecker's Avatar
thanks. If you buy the ensolite from Rammaudio they have two versions. Plain which you can use in conjunction with a spray type glue (3M type stuff) or a version with glue already attcahed tot he backside which they call peel-and-stick (this is what I used)
Old Jul 31, 2011 | 11:47 AM
  #34
fitblitz's Avatar
The peel-and-stick is what I have on order as well. I meant to ask how did you stick the heavy MLV to your door panel?
Old Aug 6, 2011 | 10:54 AM
  #35
jcuecker's Avatar
I used pieces of industrial strength type valcro. Its available at lowes.
Old Sep 9, 2011 | 06:58 PM
  #36
bunz559's Avatar
looks like it took alot of time and patience! great job! this is definitely something i may be interested in doing in the future since i am not considering modding for speed. GREAT JOB!
Old May 31, 2012 | 11:36 AM
  #37
mulletboi86's Avatar
Where do you buy the noise damping products?O'Reilly , Auto zone?
Old May 31, 2012 | 12:06 PM
  #38
jcuecker's Avatar
from a few post up
Old Jul 22, 2012 | 11:56 AM
  #39
Diasoul's Avatar
holy dayum. now this is dedication.
Old Jul 22, 2012 | 02:42 PM
  #40
Cat's Avatar
Cat
Great job! Just wish that Honda would do this on all Fits since they are aware that this is a major issue with our little cars.
