Axxess ASWC
Old Mar 28, 2012 | 08:40 PM
krunk13's Avatar
Axxess ASWC
Can anyone confirm that this product works for a GE8? Its a steering wheel control module for aftermarket systems.
Axxess ASWC Steering wheel control interface — connects your car's steering wheel audio controls to an aftermarket stereo at Crutchfield.com
Old Mar 28, 2012 | 10:46 PM
FittedOnEm's Avatar
Works just fine in my 2012. However, sometimes when I start the car, it won't work and I have to turn the ignition off for it to reset. I'm going to try changing the grounding point and recheck my wiring.
Old Apr 9, 2012 | 01:21 PM
Sooner97's Avatar
Yeah, it works great on my 2012 too. It only takes about 5 min for it to connect to your head unit and the steering wheel controls work great, no lag at all. Buy it from Amazon, it's about $15 cheaper.
Old May 8, 2012 | 07:41 AM
dcmcelreath's Avatar
How did you guys wire yours in on your 2012's? It says to tie a wire into pin 16 and pin 5, but on my harness there isnt any wires in those pins. Are they talking about the vehicles wiring?
Thanks!
Old May 8, 2012 | 09:36 AM
Sooner97's Avatar
Thanks!
You have to add the wires to those pins. Since I had ran my own speaker wires, I just pulled out the front L & R speaker wire from the harness and inserted them into those two pins.
Old May 11, 2012 | 02:53 PM
jnesselroad's Avatar
I've got my whole dash torn apart. Which wires on the aswc do I connect to 5&16? I have the black/pink wire on pin 16. But idk which to use for 5. Any quick help would be appreciated!
Old May 11, 2012 | 09:13 PM
Sooner97's Avatar
Here's the instructions for installing it in a GE:
http://contentdocs.installernet.com/...icle/10852.pdf
Grey & Red wires to pin 16 and you ground pin 5.
Old May 11, 2012 | 10:07 PM
Found that finally about 10 min after I posted. Thanks for the help!
Old May 11, 2012 | 10:28 PM
Sooner97's Avatar
No prob.. it's the least I could do since I copied your headlight design on my GE Thanks! They look awesome!
Old May 14, 2012 | 10:26 PM
OK.....
I connected the gray/red wire like it said, and grounded pin 5. For some reason, the mode button changes songs, and the channel button changes the radios source....
Any ideas?
Old Jun 16, 2012 | 05:39 PM
connor55's Avatar
Does this work for the Bluetooth controls as well? I'm getting a jvc unit and I want to be able to answer and hang up calls with the factory steering wheel controls.
Thanks
Old Aug 4, 2012 | 10:46 PM
OK.....
Any ideas?
Idk for sure, but sounds like it has the "wrong manufacturer" or something programmed. Or maybe you have them backwards?
@conner, the manual says it works w the Bluetooth too, do you have Bluetooth controls/navi?
Old Aug 5, 2012 | 04:18 PM
connor55's Avatar
I had factory Bluetooth on a non navi fit. This included some voice recognition stuff and the answer/hang up buttons on my steering wheel. I now have a navi system with Bluetooth setup, but I haven't figured out how to wire in the steering controls.
If I look at the aswc manual, it only mentions fit with navi. I do not have the pin layout that's shown in the online diagrams either. So I'm really stuck at the moment.
Old Aug 5, 2012 | 05:39 PM
Ah, you've got a Canadian model. They didn't offer bt w/o navi in the US until the 2012 if I'm not mistaken. I don't think it adds any extra wires though. I've got the esm at home, I can try to find the pin out for the Canadian model if you tell me your trim level.
Old Aug 5, 2012 | 05:54 PM
connor55's Avatar
Thanks man. Its a 2012 LX. Should be the same wiring as any other non navi bt fit I'm guessing.
There is some sort of blue tooth module in dash underneath the steering wheel. I'm assuming it's some kinda Bluetooth addon that was meant to connect to the stock stereo unit. I can post a pic or find the P/N if that helps.
Action Jackson
Apr 6, 2024 02:38 AM
timster
Jul 25, 2023 10:16 PM
Xitomatl
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Aug 20, 2019 01:46 PM
champikasam
Mar 31, 2016 03:33 AM
Mugen_Dom
Sep 21, 2007 04:16 PM
