short shifter!
Old May 10, 2012 | 09:46 PM
Smurf_GE's Avatar
short shifter!
In the process of installing a buddy club short shifter... How Do i remove the black cable from the original shifter box???? Got the white one no problem now I am lost
Old May 11, 2012 | 12:08 AM
kodok3ribu's Avatar
Old May 11, 2012 | 12:38 AM
hayden's Avatar
One you have to turn 90 degrees and pull up on, and the other just takes a lot of force to pop it out. Get a rag and screwdriver to see if you can pry against something. I've done this about 3 times on my GE and it got easier. Can't remember what I did exactly though. Use force. haha
Old May 11, 2012 | 01:44 AM
FittedOnEm's Avatar
Old May 11, 2012 | 07:19 AM
BlueBoogers's Avatar
It's a really easy process. I remove the black cable first (before the bolts).
The black cable removes by "twisting" it to the left and then it lifts out of the shifter once the retainer clip is removed where it holds against the lever bracket underneath.
峠ge8
Nov 4, 2018 11:12 PM
Vash
Apr 17, 2012 09:28 AM
Fit*est
Mar 23, 2012 05:42 PM
strmslvrfit
May 25, 2009 03:54 PM
xanatos
Aug 26, 2008 11:06 AM
