Problems locking car with remote
Old Apr 10, 2019 | 08:29 PM
headrec's Avatar
So on 2 occasions as of late my remote key won't lock and arm the security on my fit.
Today I did a little bit of research. First thing to do was open and shut all the doors. I did this a couple of times til I was able to kind of narrow it down to the rear hatch being the issue. I can't consistently get it to lock but if I open and shut the hatch a couple of times I can usually get it to lock and arm the security.
First, where is the sensor between the hatch and the body?
Secondly I also noticed the hatch auto lock mechanism isn't working anymore. Is this common? I know the doors are notorious for it. Curious if its possibly an issue outside of the mechanism. I know bad ones are known to make noises. I hear no noise.
Old Apr 11, 2019 | 12:11 AM
ChuckDustin's Avatar
Don't really know much about the subject area, but the first thing I would do is the check the fuses and key battery.
Old Apr 11, 2019 | 06:23 AM
headrec's Avatar
The key battery is fine because it unlocks just fine and I don't think there is a separate fuse just for the rear hatch .
Old Apr 11, 2019 | 09:17 AM
Auto Genius
Honda Fit (2011) – fuse box diagram
admin
2 years ago
Year of production: 2011
Interior Fuse Box
[img]data:image/svg+xml;charset=utf-8,<svg height="300px" width="213px" xmlns="http://www.w3.org/2000/svg" version="1.1"/>[/img]Honda Fit – fuse box –
interior
NumberAmpere rating [A]Circuits protected
110Back Up
2(7,5)TPMS*
320Driver’s Power Window
4—Not Used
510Back Up Light
610SRS
7(10)Transmission SOL*
88SRS
9(20)Fog Light*
107,5A/C*
117,5ABS/VSA*
1210ACG
1320ACC Socket
147,5Key Lock/Radio
157,5Daytime Running Light
1610Rear Wiper
1720Front Passenger’s Power Window
1820Rear Passenger’s Side Power Window
1920Rear Driver’s Side Power Window
2015Fuel Pump
2115Washer
227,5Meter
2310Hazard
2410Stop/Horn
25—Not Used
2610LAF
27(30)Door Lock Main*
2820Headlight Main
2910Small Light
3030Main Fan Motor
31—Not Used
3210Right Headlight Low Beam
3315IG Coil
3410Left Headlight Low Beam
35(15)Door Lock*
36(15)Door Lock*
3730ABS/VSA* FSR
38(15)Door Lock*
3915IGP
40—Not Used
41—Not Used
42—Not Used
43(7,5)MG Clutch
447,5STS
45—Not Used
46—Not Used
47(30)Sub Fan Motor
4810Driver’s Side Headlight High Beam
49(15)Door Lock*
50(15)Door Lock*
5110Passenger’s Side Headlight High Beam
5215DBW
53—Not Used
5420Rear Defogger*
5510Heated Mirror*
5630Front Wiper
5730Blower Motor
5830ABS/VSA* Motor
5920Rear Defogger
30
6050IG Main/Option Main
40
6130Radio
62—Not Used
*: If equipped
Engine compartment
[img]data:image/svg+xml;charset=utf-8,<svg height="227px" width="300px" xmlns="http://www.w3.org/2000/svg" version="1.1"/>[/img]Honda Fit – fuse box –
engine compartment
NumberAmpere rating [A]Circuit protected
1100Battery
270EPS
320Horn/Hazard
WARNING: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market.
Categories: Uncategorized
Auto Genius
Powered by WordPress
Back to top
Old Apr 11, 2019 | 11:28 AM
headrec's Avatar
Thanks for the post.
I don't see anything specific to the rear tail gate though.
The doors lock just not the rear hatch (or unlock) so probably a bad actuator.
The sensor for the rear hatch seems to be the issue but im not sure where that's located.
Old Apr 11, 2019 | 04:44 PM
Dunno man, been looking and couldnt find anything.
Sorry,
Good luck to you
Old Apr 11, 2019 | 10:03 PM
headrec's Avatar
Sorry,
Good luck to you
Hey man I really appreciate it!
Found a replacement motor for the rear hatch actuator lock for 10 bucks. The locks worked fine today but yesterday I came out to a car alarm sounding off and today my coworker said he heard it going off in the parking lot shorltly after I left it.
In theory, the rear hatch lock mechanism should be fixed by the end of the weekend but seems like whatever sensor is back there for security is the reason it's randomly not locking the doors or setting off the alarm. I could be wrong.
I also ordered a new battery for the remote just to eliminate any possible outcome. Will be resetting the ecu/car after doing this by removing the negative terminal.
Super random issue but appreciate you looking out.
hoopmatch
Sep 26, 2020 10:22 PM
magellows
Sep 24, 2018 03:56 AM
ktbishop222
Jul 1, 2017 08:34 AM
deevergote
Jan 2, 2016 08:55 PM
sterVin
Nov 18, 2008 01:22 AM
