Rear Wiper has a mind of its own
Old Apr 22, 2019 | 03:54 PM
Flashesbuck's Avatar
Not sure if this is normal to Honda Fits, but I have noticed that the rear wiper likes to run, even when its not turned on. Not all the time. But for instance if its raining out, and i have the front wiper on and I shut down the car. Then when i restart the car with the front wipers still on, I notice that the rear wiper will run about 4~5 times, then stop. The wiper stalk is set to off for the rear wiper.
Anyone else experience this behavior?
Old Apr 22, 2019 | 06:12 PM
spike55_bmw's Avatar
If you have the front wipers turned "ON" and you go into reverse "R", that will automatically trigger the rear wiper to clear the back window, thinking you want to go backwards. Could it be that?
Old Apr 22, 2019 | 10:07 PM
fitchet's Avatar
I suspect it is the behavior described above.
Which is normal.
Old Jan 2, 2023 | 11:58 AM
2008HBfit's Avatar
Ahhhh thank you for posting this! I had this happen and thought it was something electrical. I will say this... in addition to the "reverse trigger" my rear wiper did run a few times with the switch off. I have no idea what else was happening as far as what position the shifter was in or if the front wiper was on... I was just puzzled with the rear wiper behavior, so I turned it on for a couple swipes then off, but it kept running. We're getting more rain tomorrow. I will run some tests.
Old Jan 2, 2023 | 03:19 PM
gkitf16's Avatar
Mine does not come on unless, as stated, you have the front wipers turned on and shift into reverse. This makes the rear wiper cycle once
Old Jan 4, 2023 | 07:51 AM
jonshonda's Avatar
I had initially laughed at this thread as I thought for sure it was a cause of too much drug use! Granted I have only owned the fit for a short time, but did have that happen to me yesterday as well! You are not alone.
Old Jan 4, 2023 | 11:33 AM
pthompso99@yahoo.com's Avatar
Sorry--just saw today. I have same problem with my 2013 Hoinda Ft (base). No answer.
pip_rocks
May 14, 2025 01:20 PM
kkim
Jan 9, 2025 02:36 PM
dwiebe
Jul 11, 2022 08:09 PM
Bthasht
Jan 5, 2011 05:56 PM
VanIslFit
Oct 5, 2008 12:51 AM
