P0113 and P0102 engine codes.
Old Sep 22, 2019 | 07:42 AM
BotsFit's Avatar
Good day. New member here from Gaborone, Botswana.
Few day ago I bought a used 2008 GE6 from a local dealer. L13A i-VTEC. It is a RHD Import from Japan with 95,000km on the odo. Everything well and the vehicle runs perfect.
At home I did an oil and filters change. Unfortunately I did not fit the cover to the Air-Intake correctly and on engine startup I had a CEL. I checked on everything and closed the Air-Intake box properly.
Now the engine light does not go out. My OBD2 scanner shows the following codes
  • p0113 - Intake Air Temperature 1 Circuit High
  • p0102 - Mass or Volume Air Flow Circuit Low Input
I can clear the CEL but the errors does not clear. The vehicle still runs fine and I can push it up to +5000 RPM when accelerating. No stuttering. (No limp mode).
I took it back to the dealer and they swapped the Flow Meter with a working one from another vehicle. No improvement.
I can see the air-flow increase on the OBD2 software as I press the accelerator pedal. It seems to be working fine.
What do I check next. I see 5 pins on the plug. I assume (very dangerous ) ground, +12V, signal for Air flow, signal for Air temp and maybe signal ground. Does anyone have the correct pin-outs?
JMR808
Jan 13, 2023 06:17 PM
Nakor
Jan 7, 2019 07:09 AM
ecoterragaia
Dec 12, 2013 11:36 AM
A-Diggy
Jul 23, 2013 01:38 AM
Fit of RAGE
19
Apr 20, 2008 12:53 PM
