back again with some questions
Old Jan 4, 2020 | 11:10 PM
GE82010's Avatar
well my fit is at 200k miles now and idk if they ever did the thermostat change and the radiator change should i change the thermostat as im from california and i want to get ready for the hot summer this year
Old Jan 5, 2020 | 12:40 AM
SiXiam's Avatar
I changed mine at 100k, so certainly.
Old Jan 5, 2020 | 11:54 AM
Mister Coffee's Avatar
It the GE thermostat a known failure issue?
Old Jan 5, 2020 | 12:08 PM
GE82010's Avatar
well i dont know how hot my engine is getting because they only have hot or cold but its been 200k without changing the thermostat and i know the day that it fails... would be a bad idea for my little engine and i also need to change the coolant
Old Jan 5, 2020 | 12:22 PM
You think your thermostat will go before your water pump? The rule of thumb used to be to change out your thermostat when you where in there changing out your water pump.
Old Jan 5, 2020 | 03:13 PM
Red 05's Avatar
I replaced mine at 85k when I flushed coolant. I wish I had a picture but it looked brand new still. Really easy job though, sits on the side of the engine facing forward, just two bolts and it's out.
Old Jan 5, 2020 | 06:30 PM
fit09's Avatar
I recently flushed the coolant system on my 09 that had about 145K miles. Replaced the thermostat at that time as well just as a preventative maintenance thing. So if you getting ready to replace the coolant I would suggest doing the thermostat at that same time with a engine that has 200K miles just for peace of mind. Really easy to access this part on these engines as was mentioned earlier.
Old Jan 6, 2020 | 07:53 AM
GE82010's Avatar
yea i might start to order the thermostat and the coolant soon thank u guys so much
Old Jan 6, 2020 | 10:59 AM
Red 05's Avatar
remember the replacement rubber seal that goes with it, you need to replace it when you open it up.
Old Jan 6, 2020 | 12:39 PM
GE82010's Avatar
alright bro is the rubber seal also for sale on hondapartsnow?
Old Jan 6, 2020 | 01:57 PM
Red 05's Avatar
Probably? I bought it at an Advance auto for less than 6 bucks, same place I got my thermostat. It's a very common size.
Old Jan 6, 2020 | 06:51 PM
eulogy's Avatar
yea man, just swap that. im going to swap mine along with the coolant in the spring and i have 66,000. cheap insurance with easy access.
Old Jan 6, 2020 | 11:17 PM
SiXiam's Avatar
I bought a thermostat on eBay that came with the gasket, back in March 2019.
Old Jan 7, 2020 | 12:38 AM
hotkey's Avatar
That's what I would do.
Old Jan 8, 2020 | 05:29 PM
SiXiam's Avatar
I don't really understand this. Changing your water pump with the thermostat.
Water pumps last a lot longer and it is in a different spot with having to take off the serpentine belt.
All I can say is at 100k miles my pump is fine, but changing the thermostat gave me a car that heats up quicker in the winter.
I've read posts here with 200k+ mile cars on the original water pump.
If anything I think changing the water pump should be done when you change the alternator.
Old Jan 9, 2020 | 12:14 AM
hotkey's Avatar
My bad. What I should have said was "what I used to do." Water pumps didn't last very long back then. Something to do with coolant and pump material quality. Old habits die hard.
krunk13
Mar 27, 2013 06:27 PM
idkmybffjill
Jun 30, 2011 07:47 PM
sonicsc1
Mar 28, 2009 10:32 AM
Batman
Dec 1, 2007 05:54 PM
Krystyne
Sep 29, 2005 07:30 PM
