A lot of question with the dealers, and break making noise.
Old May 3, 2020 | 10:47 AM
ijusttesting's Avatar
Question A lot of question with the dealers, and break making noise.
I have a 2013 honda fit, with 57000km , mainly city driving
visited the dealer before the city lockdwn.
the dealers recommended:
  1. drain brake fluid ( did it 2.5 years ago, so i refused)
  2. changed air filter and pollet filter, which i changed 2 years/14km ago, so i also refused
  3. changed the automatic transmission fluid because it's "light pink"
  4. changed the belt because it's crack (ok, i see the crack, if i see the same belt)
  5. wheel alignment (ok, i am guilt about it)
My question is,
  1. I read the owner it's stated the automatic transmission fluid should be good for the first 96000km, but did not state time flame
  2. does the bad belt caused trouble with the transmission shifting issues?
  3. My other question - about a month later, the front breaks start making noise. It's make noise when i pressing it at slow speed (about 30k or slower). It is not load, but it's enough when i can hear them when breaking. (they claimed my break is ok in March.)
Thx
Last edited by ijusttesting; May 3, 2020 at 11:28 AM. Reason: car was 57km, not 67km
Old May 3, 2020 | 11:15 AM
Red 05's Avatar
Originally Posted by ijusttesting
I have a 2013 honda fit, with 67k , mainly city driving
visited the dealer before the city lockdown.
  2. changed air filter and pollet filter, which i changed 2 years/14k ago, so i also refused
My question is,
  1. I read the owner it's stated the automatic transmission fluid should be good for the first 96k, but did not state time flame
Thx
96k miles is too far an interval for transmission. You should have your first around 60k, subsequent changes every 36k. Brake fluid needs to be changed every three years. Air filter is dependent on what sort of environment but 15k is a good service window for filters.
I have no idea how you draw a correlation between "belt" and transmission shift quality, there isn't. Only belt that needs changing on the car is the serpentine belt and that needs to happen around 100k or so, sooner if the rubber perishes. Brakes last a while on the second gen but 60k is a good time to change them.
Old May 3, 2020 | 11:24 AM
Sorry, my mistake, the car was 57000km.
the transmission shift rough until the transmission fluid and serpentine belt changed. So i come up to this conclusion.
Old May 3, 2020 | 11:46 AM
Frenzal's Avatar
I'm at near 90k km, and my maintenance minder never came on for the transmission fluid...
Old May 3, 2020 | 01:22 PM
i guess they are upselling services i don't need?
Old May 3, 2020 | 01:51 PM
Red 05's Avatar
Ah ok, I didn't pick up you were in klicks. Sorry, all my figures are in miles.
eigger19
Feb 11, 2023 02:01 PM
sandz
Apr 23, 2014 09:06 PM
bryanska
Jul 9, 2013 01:56 PM
rockangelz
Nov 23, 2012 02:09 PM
gkitf16
Dec 29, 2011 05:27 PM
