Nipple size for front and rear brake bleeder valve?
Old Aug 8, 2020 | 07:27 PM
StGemma's Avatar
Hola,
Does anyone know what the nipple size is for the front and rear brake bleeder valve? I want to get a bleeder valve kit with the hose and pump, so, as most of you folks know, having the correct hose size to fit very firmly on the valve will be crucial.
Thanks.
Old Aug 8, 2020 | 08:16 PM
SiXiam's Avatar
I'm not sure. I used this for mine:
Amazon Amazon
Be warned some of your bleeder valves may be really hard to turn. I barely got my rear one tightened and bought a replacement in case I ever have to mess with it again.
Old Aug 8, 2020 | 09:05 PM
StGemma's Avatar
Thank you for the response. Yeah, I purchased an 8mm and 10mm flare nut wrench, so hopefully that will be sufficient.
I've never bled the brakes for my Honda Fit, so I was also wondering how many ounces will I need to replace for all four brakes, and where may I take the old brake fluid to dispose of? Does Walmart accept brake fluid?
Thank you.
Old Aug 8, 2020 | 09:44 PM
SiXiam's Avatar
Most auto parts store take old fluid. I don't know it by ounces. I had a large bottle of brake fluid and a normal size one and only used the large one.
One technique that is helpful is get one of those baby nasal aspirators to drain the fluid out of the reservoir, before putting new stuff in. You can't get it all, but it saves you some time. Some people do this routinely, like every year without bleeding.
Old Aug 8, 2020 | 10:52 PM
StGemma's Avatar
Oh, good to know! I'll have to ask AutoZone, or something. Do you remember what size the large bottle was in milliliters, grams, lbs, etcetera?
Just wondering: why remove the brake fluid from the reservoir? I've heard and read the service manual, and others, say to not let the brake fluid go below the minimum, because that is a risk of letting air in.
Also, does anyone know what size Speed Bleeder that will fit for the 2012 Fit, and which brand is good? Would be nice to install those.
Edit: Awesome, found this thread, which answers my third question. https://www.fitfreak.net/forums/2nd-...rew-sizes.html
Old Aug 10, 2020 | 07:28 PM
SiXiam's Avatar
I think Prestone 12 oz and 32 oz. I answered the other part about the saving time and doing it routinely.
Old Aug 11, 2020 | 08:42 PM
StGemma's Avatar
Ah, gotchya. You did say that. Great, thanks for the information.
I actually went to the Honda dealership today and it was only about $7 for the brake fluid for a 12 ounce bottle. Not too bad.
ddson33
May 31, 2020 02:44 PM
mtrexler
Jun 26, 2019 05:58 AM
amberd03
Aug 20, 2017 11:57 AM
utsug
May 20, 2016 12:03 AM
icedmocha
Feb 9, 2015 05:58 PM
